Re: Could someone look this over?
I'll have to play with it some, oh, wait, as I was sitting here I just got an idea. It might not be doing the conversion from a unsigned char to an int correctly. Maybe an explicit cast will help... ![]() ![]() As I said in a previous edited post, we have used dashboard on it and it appeared to work then, but I'm not sure about the version I was using. Thanks for your help. Last edited by Ryan M. : 08-02-2004 at 12:18. |
Yes!
![]() ![]() ![]() ![]() PS Excessive celebration, 5 yard penalty. Any more suggestions appreciated. Thanks Last edited by Ryan M. : 08-02-2004 at 12:19. |
if(currentPWM >= goalPWM + sensitivity)
return currentPWM - sensitivity;
if(currentPWM <= goalPWM - sensitivity)
return currentPWM + sensitivity;
If goalPWM is 254 and sensitivity is 10 and CurrentPWM is 127, the result of (goalPWM + sensitivity) is 8 and so CurrentPWM is greater then 8 and you return 117 not 137 like you hope. |
And the funny thing is, I had already paritially taken looping around into acount in the code. Last edited by Ryan M. : 08-02-2004 at 12:27. |
