Go to Post it was beautifull just beautifull... then i took my earmuffs off. - Tytus Gerrish [more]
Unread 08-02-2004, 11:44
milesdf's Avatar
milesdf milesdf is offline
Yaaaaa!
AKA: Yaaa!
#0836
milesdf is an unknown quantity at this point
Shorten The Flexible Drive Shafts?
Can The Flexible Drive Shafts Be Shortened?
If not, can we buy shorter ones?
Miles
Unread 08-02-2004, 12:17
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: Shorten The Flexible Drive Shafts?
I doubt you would be able to. I remeber my team tried to years ago and it did not work well. The flexible drive shafts are composed of lots and lots of tiny wires to make a flexible square shaft. They make it fairly hard to get a clean cut off of them.
Unread 08-02-2004, 12:27
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
we pulled the black covering off of them one year then welded the end and, grinded it so that it would stay sqare, to the end that we cut to stop the wires from squiggling this way and that.
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
