Go to Post cue Dave Lavery with some witty response - Taylor [more]
Unread 04-02-2004, 22:14
Atheist Atheist is offline
Atheist is on a distinguished road
IR signals inverted
For some reason the EDU controller is interpretting signals on the first and second digital inputs as 0 and no signal as 1. Am I missing something or is this not correct? I use PrintByte() to print the value of each and the beacons/sensors are functioning perfectly. What could be causing this?
Unread 04-02-2004, 22:21
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Re: IR signals inverted
Well the IR sensor (Spec Sheet), will output a logic high (+5v) when it does not see a signal, and a logic low (0v) when it does see a signal. This appears to be what you are seeing.
Unread 04-02-2004, 22:29
Thanks, so it would seem that they were working after all.
Unread 04-02-2004, 22:37
Those are the best kinds of problems.
Unread 04-02-2004, 23:40
Kevin Watson's Avatar
La Caņada High School
FRC #2429
This illustration shows what the sensor output should look like.
-Kevin
Kevin Watson
http://kevin.org
Unread 06-02-2004, 16:19
Actually I don't think it has anything to do with the sensor output. When I manually connect the pins it reads as 0 and when they are not connected it reads as 0.
Unread 06-02-2004, 16:27
is it possible you redefined the port in your code somewhere to make the pin an output instead of an input?
is it possible you connected something to the pin that you shouldnt have, like 12V, and blew out the input circuit for that pin?
I would look up how to connect a simple switch to the port (in the RC reference manual) and try reading the port that way - you cant get any simpler than a switch - if the pin is blown out, and you dont need to use all your input pins, then use another one.
Unread 06-02-2004, 16:32
Anything is possible, but not likely. I've triple checked the code to make sure they are inputs. What I said is true for EVERY pin on the EDU controller. I tried the switch method with the same result.
Unread 08-02-2004, 11:24
Any ideas? Am I missing something?
Unread 08-02-2004, 13:20
Yep, you should get 1 when the signal pin is disconnected and 0 when a switch connects it to ground.
How are you displaying the value? Are you typecasting (int) the char value?
e.g.,
printf("rc_dig_in1 = %d\n", (int)  rc_dig_in1);
Just to verify your User_Initialization() should have:
  IO1 = IO2 = INPUT;
/* SECOND: Configure the number of analog channels. */
  Set_Number_of_Analog_Channels(NO_ANALOG);     /* See ifi_aliases.h */
Unread 08-02-2004, 16:27
Ok, that is what we are getting. 1 when disconnected and 0 when connected.
Radios not getting signals BrendaB Control System 3 24-01-2004 22:50
nats: stoping conflicting robot signals? JasonStern Technical Discussion 25 25-05-2003 00:37
visual signals from operator allowed? angelina Rules/Strategy 16 23-01-2003 20:11
Referee hand signals archiver 1999 1 23-06-2002 21:57
problems with receiving signals between radios (need help0 chrisw Technical Discussion 4 11-01-2002 10:35
