Go to Post I'd say go out and kick their collective boo-tays...in a non-damaging, graciously professional manner, of course. (wink wink) - Billfred [more]
Unread 08-02-2004, 15:15
mightywombat's Avatar
mightywombat mightywombat is offline
bins? stacking?? NOOOOO!
AKA: Bill Rosemurgy
#0857 (Superior Roboworks)
mightywombat is on a distinguished road
volatile keyword
What does the volatile declaration mean?
ie (from kevin.org/frc timer demo)
volatile unsigned long msClock =0;
Bill Rosemurgy - Aspiring Programmer and Human Player (stack of 8 in <10 seconds...oh yeah... but I can't shoot for crap.)
www.team857.com
Unread 08-02-2004, 15:21
AKA: Bill Rosemurgy
Re: volatile keyword
as an addition to my last post, what does the keyword static mean as well? as in:
static unsigned int divisor =0;
www.team857.com
Unread 08-02-2004, 15:34
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Volatile is a hint to the compiler to tell it that the memory location where the variable which was declared "volatile" is stored can change without the compiler knowing about it. This is significant, because a common optimization that a compiler will make with variables is that it will try to minimize the number of times a variable is copied out of RAM and into a register inside the CPU. Meaning if you use a variable named "blah" several times in a function and it's stored in the memory address 1234, the compiler will copy the value from memory location 1234 to a register at the beginning of the function, then use the register each time your code accesses that variable, and then just save the contents of the register back to memory address 1234 at the end of the function.
When you tell the compiler that a variable is "volatile" it means that it can be changed by something other than the code which the compiler is generating. So, when the compiler sees this, it does not cache the variable in a register and instead reads it directly out of RAM each time it is needed. Where this becomes important is on the digital I/O for example. The digital inputs are memory mapped (meaning to read the digital inputs, you just read a memory location). If these are not declared volatile, each time you access the digital inputs you may not be receiving the newest available data. So, if you go and look at ifi_picdefs.h, you'll see that all the CPU registers are declared volatile for this reason.
Hope that made sense, it's pretty tricky to explain in text without a whiteboard . Let me know if you want me to clarify any part of it...
Unread 08-02-2004, 15:37
Electrical Engineer
Rookie Year: 1995
Volatile is an ANSI C storage qualifier that tells the compiler that a value in that storage location can not be trusted.
From the MPLAB® C18 C Compiler User’s Guide:
2.9.2.2 INTERRUPT SERVICE ROUTINES
Global variables that are accessed by both an ISR and mainline functions should be declared volatile.
What does this mean? Let's assume you are doing a simple math operation. One operand is in a register and the other is a memory location. The compiler will not use the memory location for a volatile variable. This becomes very important for a complex mathematical line such as:
x = x * m + b; // where x is a variable modifiable by an ISR.
In this example, if x is stored with x*m and the ISR modifies x before x+b occurs, you get the wrong answer... The volatile keyword prevents this from happening.
Regards,
Mike Betts
As easy as 355/113...
Unread 08-02-2004, 15:38
volitile tells the compiler not to assume the memory location of the variable retains it's value. It will check that the variable has the correct value whenever your code uses it.
static tells the compiler to always retain the variable's value.
You'll want to use static quite often.
In the following example, divisor will increase in value every time My_stuff() is called, but x will always start fresh as 0 each time and increase to 1, before being lost when you exit the routine:
void My_stuff()
  unsigned int x=0;
  x++;
  divisor++;
Unread 08-02-2004, 15:39
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Static means that only one copy is used of the variable in all instances of the function. For example,
void foo(){
static int count = 0;
count++;
printf("%d", count);
int main(int argc, char *argv[]){
while(true)
foo();
would print out 123456789101112, etc whereas
void foo(){
int count = 0;
count++;
would just print out 1 every time since the function can't keep track of things between calls.
As for volatile, it basically tells the compiler that it's possible that something other than the program itself could change the value of this variable, so don't try to do any crazy optimization stuff. Chances are that you won't really need it much (if ever), but it's good to know its there just in case.
-Rob
Unread 09-02-2004, 10:54
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
static can also be used outside a function. When used on a global variable, it is then only accessable to the functions in that file. It is impossible for a function out side the file to use it.
Unread 09-02-2004, 13:32
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Actually, that is how normal "global" variables work. they have file scope. To increase the scope you need to use extern (see above).
Unread 09-02-2004, 15:46
Programming User
static prevents the use of extern.
Unread 09-02-2004, 16:12
AKA: Chris
Ahh, I did not know that. Thanks.
Unread 11-02-2004, 06:56
Programming User
Actually, here's what really happens. A normal golbal variable is accessible to any file, but in order to use it, the file has to be told it exists. Hence the extern. Static limits the scope to the file. If you know C++, an unnamed namespace does the same thing as static, when used on a global variable.
Using the extern keyword. D.Viddy Programming 7 20-01-2004 21:22
