Go to Post Be not afraid, go forth and multiply. - Pat Major [more]
Unread 08-02-2004, 18:15
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Re: Jaw Coupling
http://www.chiefdelphi.com/forums/showthread.php?t=18595&highlight=technokat+couplin g
The post by Andy tells what we had to do to them so that they would work.
Purdue Alumni
Cummins, Inc.
Unread 08-02-2004, 19:54
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Re: Jaw Coupling
The CEC coupling is great. We did end up using it (after modifying it as per Andy's guidelines for 3/8" shaft). These things don't weigh hardly anything and work great. Just make sure MSC has them in stock before you purchase them.
For each side you will need 2 hubs and one spider to comlete the coupling. You also want to purchase the Buna-N spider (the softest of the 3, the other 2 are too hard for most applications)
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 08-02-2004, 21:06
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: Jaw Coupling
Yep, these couplings are nice. We did not strip the keyway in the composite, but we were worried about it. So, we boached a hex hole in the composite part and put a hex sleeve piece of aluminum in it's place. This hex sleeve had a 3/8" hole with a 1/8" keyway in it, just like the composite coupling had.
Good luck,
Andy B.
Globe Motor Coupling MechaJag Motors 5 24-01-2004 18:12
coupling Bosch & Atwood motors caffel Motors 10 28-05-2003 16:00
SPI Wheel coupling cracking like crazy! archiver 2001 4 24-06-2002 00:56
Motor coupling archiver 2001 19 23-06-2002 23:35
3.5x3.5 coupling? ahecht Technical Discussion 1 05-01-2002 23:36
