Go to Post But really, FIRST attracts all kinds of people; nerds, geeks, dorks, preps, techies, PR people, financial persons, etc. - Dorienne [more]
  #31   Spotlight this post!
Unread 21-01-2004, 21:28
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: New Joysticks...Good or Bad Choice by FIRST?
Originally Posted by Phish32786
(tight turning maybe with out forward thrust?) I think that would be really cool.
you could do this without joystick twisting - simply make it so that when you push the joystick full to the right or left, the appropriate motor is not simply full-stopped, but instead reversed - i.e. the first 3/4 of the joystick motion to the left slows the left motor, the last 1/4 speeds it up again, but in reverse. then simply push the joystick up and right or up and left to turn sharply.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
  #32   Spotlight this post!
Unread 21-01-2004, 21:30
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Originally Posted by Anthony Kesich
Those are null wheels. They adjust the offset and are used to null the joystick. What we're looking for is a wheel that gives its own analogue output, not just adjusts another.
Just wire your own. Look in the FRC default code doc for the tables. you can add 2 (Unless the D-pad uses them).
  #33   Spotlight this post!
Unread 21-01-2004, 22:32
CyberWolf_22's Avatar
CyberWolf_22 CyberWolf_22 is offline
Programming and Electrical Mentor
AKA: Allen Gregory
FRC #2587 (Afrobots)
CyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really niceCyberWolf_22 is just really nice
The directional pad on top of the joystick does take one of the analog inputs but there still is that second one you can use to make your wheel that was on last years joystick with a pot and a piece of wood or metal cut into a circle.
  #34   Spotlight this post!
Unread 22-01-2004, 07:30
AKA: Jamie Bliss
To use a pot, all you need is to drill a hole. There's a litttle nut on top to attach it.
  #35   Spotlight this post!
Unread 22-01-2004, 09:46
Corina Martinez Corina Martinez is offline
Corina Martinez is an unknown quantity at this point
Joysticks can we buy are own?
Can we buy are own joysticks or do we have to use the one's that FIRST gave use?
  #36   Spotlight this post!
Unread 22-01-2004, 10:04
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
you can buy your own
  #37   Spotlight this post!
Unread 22-01-2004, 15:44
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
It looks like the reason that FIRST went with the new sticks is that CH Products has discontinued the Flightstick. However, you can still buy the Flightstick Pro (the 4 button version of the Flightstick) for around $15 from places like PC Connection. I can't personally vouch that the quality of the Flightstick Pro is the same as the Flightstick, but it is ambidextrous and has been well reviewed.
For those of you who really want the old 2-button Flightstick, you can buy them for $30 from FlightSim Central.
Zan Hecht
  #38   Spotlight this post!
Unread 22-01-2004, 16:45
ComputerGeek ComputerGeek is offline
ComputerGeek is an unknown quantity at this point
just to let you all know, the directional pads on the top of the new sticks are called hats
personally i think that the new ones should be used for things other than driving. that way drivers can still use 2 joystick driving.
  #39   Spotlight this post!
Unread 08-02-2004, 14:28
Aignam's Avatar
Aignam Aignam is offline
This Space For Sale
AKA: Anthony Mangia
#1257 (Parallel Universe)
Team Role: Scout
Aignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant futureAignam has a brilliant future
Send a message via AIM to Aignam Send a message via Yahoo to Aignam
I can't find the old Flightsticks on there. Does anyone know where they are, or where I can get them?
Some Thoughts to Ponder
How does a sign turn into a lady friend? Don't optional stop signs ruin the purpose? What are pneumatics? Am I really banned from 229 for life? Can walls get bigger?
Aignam. Pronounced A-Num. Mangia backwards.
NJFIRST.org | Best Thread. Ever.
AIM: Aignam | ICQ: 265237569 | E-mail: AnthonyMangia@aol.com | HTTP: www.aignam.com
  #40   Spotlight this post!
Unread 08-02-2004, 14:43
edomus's Avatar
edomus edomus is offline
AKA: Evan
FLL #1218 (CHAbots)
Team Role: Driver
edomus is on a distinguished road
Send a message via AIM to edomus
Looks like I got the last ones
2004 National Finalists with 469 and 868
2004 Gallileo champions and #1 seed
  • Delphi "Driving tommarows technology" -philly 2004
  • 8th seed philly 2004
  • 58/58 at annapolis 2004 (like the improvement?)
  • Philadelphia Alliance Regional Winner!-2003
  • 7th seed Philly 2003
  • Rookie all star philly 2003
  • semi finalist Pitt 2003
  • picked 3rd in pitt 2003
  • Seeded 17(curie) at nats 2003
  #41   Spotlight this post!
Unread 08-02-2004, 15:30
Aignam's Avatar
This Space For Sale
AKA: Anthony Mangia
Team Role: Scout
  #42   Spotlight this post!
Unread 08-02-2004, 16:19
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Originally Posted by AlphaOmega870
Is there any other way to adjust sensitivity?
Look at the thread, desenetizing joysticks, for more than you'll ever want to know about cutting down on the crazy sensetivity of the joysticks.
  #43   Spotlight this post!
Unread 08-02-2004, 18:04
David Bryan David Bryan is offline
#0818 (Steel Armadillo)
David Bryan is an unknown quantity at this point
The Joystick Does have p1_wheel but it only gives 5 values which we can use.
Leave centered p1_wheel = 45
push right = 202
push forward = 254
push left = 98
pull back = 149
These are approximate but you can make 4 decisions with these directions.
This assigned p1_wheel control is between p1_sw_aux1 and p1_sw_aux2.
David Bryan
818
  #44   Spotlight this post!
Unread 08-02-2004, 18:10
SeanCassidy's Avatar
SeanCassidy SeanCassidy is offline
Antiregistered User
#0263 (Aftershock)
SeanCassidy is an unknown quantity at this point
I wrote a function like this to find what buttons where what on the joystick (The same joystick first gave us.)
void Default_Routine(void)
  if(!p1_x)
    printf("p1_x\n");
  if(!p1_y)
    printf("p1_y\n");
  if(!p2_y)
    printf("p2_y\n");
  if(!p1_wheel)
    printf("p1_wheel\n");
  if(!p1_aux)
    printf("p1_aux\n");
  if(p1_sw_trig)
    printf("p1_sw_trig\n");
  if(p1_sw_top)
    printf("p1_sw_top\n");
  if(p1_sw_aux1)
    printf("p1_sw_aux1\n");
  if(p1_sw_aux2)
    printf("p1_sw_aux2\n");
What I couldn't find on the joystick themselves were p1_wheel, and p1_aux. Also, when I pressed the hat in different directions, nothing happened. Any ideas?
  #45   Spotlight this post!
Unread 08-02-2004, 19:21
Computer Guy
AKA: Dav
  if(!p1_x)
    printf("p1_x\n");
  if(!p1_y)
    printf("p1_y\n");
  if(!p2_y)
    printf("p2_y\n");
  if(!p1_wheel)
  if(!p1_aux)
    printf("p1_aux\n");
  if(p1_sw_trig)
  if(p1_sw_top)
  if(p1_sw_aux1)
  if(p1_sw_aux2)
well, the hat control *should* be showing up as p1_wheel, and p1_aux is not used on the new joysticks.
also, most of the values are not boolean values - that is, you can't really use an if statement to check them. for instance, the wheel will never show up, because it is a analog value from 0-255, but in the case of the hat it is never 0 - it's neutral value is somewhat above zero. Same goes for the joystick x and y axis - they are analog values from 0-255.
Vanilla Coke..good? bad? A. Leese Chit-Chat 41 07-01-2004 00:15
college counseling decides to help us... good or bad? AlbertW General Forum 4 16-05-2003 15:14
NYC Regional- Give me the good, bad, or ugly... Rich Wong Regional Competitions 23 28-03-2003 17:56
Chiaphua Motors: Good or Bad to 2002 Kit Of Parts? D.J. Fluck Motors 25 05-07-2002 16:40
good idea or bad? archiver 2001 4 23-06-2002 23:08
