Go to Post There are so much more things to be worked on and are more beneficial to FIRST and FIRSTers than green dots by someone's name. - tiffany34990 [more]
Unread 08-02-2004, 17:49
Dmitri Dmitri is offline
Carthaginian
#1353 (The Gizmos)
Dmitri is an unknown quantity at this point
Before I break anything...
...what is a safe method of removing the globe motor gearbox?
When in danger or in doubt, run in circles, scream and shout.
Originality is achieved when you stop thinking relative to the box.
Unread 08-02-2004, 21:18
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Before I break anything...
Umm. not removing it. I have no suggestions, but I'd like to point out that I'm pretty sure the globe gearbox is considered part of the globe motor, so any modifications of it are illegal. So unless you're just taking it apart to grease it up, I'm not sure why you'd want to....
Unread 08-02-2004, 22:28
Carthaginian
#1353 (The Gizmos)
Erm, no, that's allowed AFAIK.
Unread 08-02-2004, 22:32
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
If you guys had read the rules you wouldnt be feeding this poor guy false information.
<R62> "The gearboxes for the Fisher-Price, Drill, and Globe motors are not considered “integral” and may
be separated from the motors. FIRST will not provide replacement for parts that fail due to
modification."
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 08-02-2004, 22:33
You're wrong. <R62>
Unread 08-02-2004, 23:02
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Use a small diameter punch to press the roll pins in about 5 mm or so. After you have all 3 pushed in enough to clear the gearbox housing, you can simply remove the motor from the gearbox.
Don't lose the roll pins if you want to get it back together again.
Joe J.
Unread 10-02-2004, 20:10
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
YOu can make anymods that dont affect the motor itself, as I recall. You can even drill out the body if you don't touch the guts of it. Gearboxes are fair game.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 10-02-2004, 20:36
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
very carefully...
Break Down of Awards By Fields. Josh Hambright Championship Event 13 09-04-2003 10:22
Image Discuss: Team 624 takes a coffee break?!?! CD47-Bot Robot Showcase 4 21-02-2003 09:42
Taking a break to give thanks. Johca_Gaorl General Forum 8 07-01-2003 13:59
Switching the break mode archiver 2000 2 23-06-2002 23:28
FIRST takes a 27 year break purplehaze357 Rumor Mill 2 16-04-2002 09:16
