Go to Post Admitted to MIT '14. FIRST is good stuff. - sparrowkc [more]
Unread 09-02-2004, 00:29
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
Re: Weight Issues
Originally Posted by AdamL118
what modifications have teams done to make an effective plow?
well, there's lots of stuff you could do. you have, for example rollers on your robot to herd the balls. if you put another roller on the end of a large square that flips down from an initial standing position, you could trap the balls that you have in front of you at that point inside a corral of sorts. you probably wouldn't want to make it any bigger than, say, enough for 3 balls, but its better than nothing. something like that would let you actually grab balls and move around with them, instead of just hitting them.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
reducing gear box weight mickjagger Technical Discussion 16 23-01-2003 20:35
issues with if then else Andrew Rudolph Programming 1 15-01-2003 09:15
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
weight and size of parts Greg Needel Kit & Additional Hardware 2 27-01-2002 23:25
Robot dimensions & weight restrictions revealed? Mike Soukup Rules/Strategy 4 24-10-2001 20:51
