Go to Post MAVERICKS, do ride horses...all while building robots. They also build horses. - Corey Balint [more]
Unread 09-02-2004, 09:46
Brawler006 Brawler006 is offline
#1206 (Wrench Warriors)
Brawler006 is an unknown quantity at this point
Gum Rubber
Does anyone have any tips on attaching gum rubber to aluminum? I was thinking about using either contact adhesive or epoxy. Any help would be greatly appreciated.
Unread 09-02-2004, 11:05
Rich Kressly's Avatar
Rich Kressly Rich Kressly is offline
Robot/STEM troublemaker since 2001
no team (Formerly 103 & 1712. Now run U.P. Robotics (other programs))
Rich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond reputeRich Kressly has a reputation beyond repute
Re: Gum Rubber
You want to talk to team 222. They are the gum rubber wheel specialists.
technology, innovation, and invention without a social conscience will only allow us to destroy ourselves in more creative ways
Unread 09-02-2004, 11:30
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
Re: Gum Rubber
Dave and his wheel o' signatures
Unread 09-02-2004, 11:59
R2K2D2 R2K2D2 is offline
AKA: Raj
R2K2D2 has a spectacular aura aboutR2K2D2 has a spectacular aura about
Send a message via AIM to R2K2D2
Re: Gum Rubber
Well, there are many ways to attach it. First is by the methods you stated before, second is to just purchase the material with adhesive on the back. If you are looking for neoprene, McMaster-Carr sells it with an adhesive backing already. So, you pull the wax paper off and apply it where you want it.
Unread 09-02-2004, 13:04
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Re: Gum Rubber
yup we got gum rubber......one thing we thought about last season was how to attach the gum rubber to our wheels....well instead we bought thick sheets of gum rubber and cut a full size tire out. Then we used a split ring type wheel made from aluminum to capture the gum rubber. The design is kinda tough to explain here, but if you have more questions and AutoCAD feel free to PM me I have detailed drawings of how we made our wheels.
The reason we didn't just used gum rubber with adhesive or thin gum rubber wrapped around a rim and screwed to the rim was to handle the torque our machine put out last year.
Cliff
222 Alum.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 09-02-2004, 23:41
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
Re: Gum Rubber
Cliff
222 Alum.
There is one drawback to this method though, the wheels weigh 8lbs each, or something close to that. We had dullies, so i am sure singles would weigh much less and a hole saw could help a lot. Good luck!
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 10-02-2004, 15:49
Re: Gum Rubber
Thanks for all your help, but i'm not making wheels, i'm attaching it to the end of a pneumatic cylinder. We made aluminum mounts that screw onto the end of the cylinders, and we need to attach gum rubber to the bottom of that mount.
Unread 10-02-2004, 16:49
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
Re: Gum Rubber
Epoxy would work but make sure thats where you want it....
Unread 12-02-2004, 07:57
henryBsick's Avatar
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
Re: Gum Rubber
We had gum rubber on the end of our wings last year too. I would imagine yours would be a similar application as far as attaching goes. We cut the gum rubber out with a whole saw and there was a little hole in the middle because of thise. all we did from there was take our little gum rubber whole and a bolt with a flushable alan head on it and screwed it in tight enough so that you could only feel the gum rubber fom the surface. The bolt was indented into the gum rubber. Just watch how much pressure you put on the gum rubber. Ours popped off almost every match. We ended up using nylon slides instead because there was no need for grip in our application. PM Cliff if you would like to see a drawing he can find one i hope, or make one. Sorry Cliff i am not so proficient in CAD.
Mechanical Engineer
Digital Lumens
NU ME: 2011
Rubber for Attaching to Wheels Yan Wang Technical Discussion 3 12-02-2003 21:06
Adhesive, Brecoflex, Rubber, and M17 Madison Technical Discussion 14 09-01-2003 10:57
sheet rubber Adams High Man OCCRA 1 20-10-2002 10:07
Rubber Treads Anyone? archiver 2000 10 24-06-2002 00:29
Use of liquid rubber for padding dimroed Technical Discussion 1 22-02-2002 08:43
