Go to Post I do know a lot of teams need to be saved from themselves. - Karthik [more]
Unread 09-02-2004, 16:16
pryoplasm's Avatar
pryoplasm pryoplasm is offline
Pit Crew/Electrical
AKA: Russ
#0069
pryoplasm can only hope to improve
update 8 clarification, drill motor and blue wires
update 8 mentions something that if i cannot desolder the blue wires on the 1/2" drill motors, or at least have the wires 1.5" long, can i cut it short if i use solderless connectors?
Cut these eyes, but I will see,
Kiss these lying lips for me,
Stroke this skin, and I will kneel,
Brutalize me, I will heal...
-KMFDM
Unread 09-02-2004, 17:39
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: update 8 clarification, drill motor and blue wires
The issue is that you have to have professional level soldering skills to desolder the blue wires and resolder larger wire to the brush holders. So just don't go there. The brush holders are flimsy to say the best about them. You can shorten the blue wires to 1.5 inches and solder number 10 or larger to the shortened blue wire. First has had way to many drill motors get broken by trying to unsolder and resolder larger wire to the brush holders.
Unread 09-02-2004, 18:20
pryoplasm's Avatar
Pit Crew/Electrical
AKA: Russ
#0069
thanks, i understand that, but i was talking about solderless terminals, the kind that you simply crimp on.....
anybody?
-KMFDM
Unread 09-02-2004, 18:28
kpugh's Avatar
kpugh kpugh is offline
Has anyone seen my sanity?
AKA: Kristin Pugh
kpugh is just really nicekpugh is just really nicekpugh is just really nicekpugh is just really nice
From FIRST:
"Caution advised regarding the ½” drill motors.
You may not replace the blue wires, however, you may shorten them such that there is a minimum of 1.5 inches still attached to the motor and solder heavier gauge wire to their cut ends. Do not attempt to unsolder the blue wires from the brush housings.The plastic brush support housing will distort if exposed to soldering temperatures and the alignment of the brushes will be affected, which can permanently degrade motor performance."
This is a caution to benefit you so that teams do not accidentally destroy their motors or cause them to not perform as well. You can solder or crimp or do anything else to the blue wires as long as those blue wires are at least 1.5 inches long and still attached to the motor (having never been tampered with). This update is for our benefit!!!!
Unread 09-02-2004, 18:37
EIROBOTICS86's Avatar
EIROBOTICS86 EIROBOTICS86 is offline
#0311 (Red Jammers)
EIROBOTICS86 can only hope to improve
Send a message via AIM to EIROBOTICS86
we took them off before this update so what is gonna happen
Unread 09-02-2004, 18:58
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
our team actually did the same thing, before the update regarding the wires. In order to fix the problem, we simply re-soldered the wires to the electric connects. We've run the motor qutie a bit and nothing seems to be wrong with them. We were stuck and so we just don't plan on letting the inspectors know about the little re-wiring. The rule is there to keep rookie teams from melting their motors and there realyl is no way to tell the difference between the way you soldered on the wires and the way the corporation soldered them. I would be quite careful though re-soldering those wires on...using some needlenose pliers as heatsink would be such a bad idea.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 09-02-2004, 19:25
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
To clarify ShadowKnight's post regarding team 1123, we were going to have one of the electrical engineers on our team replace the wires to help dissipate heat to the motor (thinner wire=more resistance=more heat) Anyway, we had the wires off of one motor and then the update was issued. We then soldered the wires back onto the motor. Since FIRST did not issue this as a rule until now, we are just going to use the motor as is. We were well within the rules when we did this.
Unread 09-02-2004, 19:49
from FIRST Q/A
Section: 5.2.7 Status: Answered Date Answered: 2/5/2004
Q: Last year we SUCCESSFULLY replaced the blue wires on the drill motors under a controlled soldering process. Is this now ILLEGAL or just not advised due to the potential damage,if temperature is not carefully controlled?
A: Not illegal but ill-advised for the well intentioned novice.
Unread 09-02-2004, 19:50
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Sorry, but youre wrong. Ive seen many many veteran teams screw up their drill motors by desoldering them. It has nothing to do with how long a team has been around, or even to some degree the skill of the person soldering. The reason they want you to avoid it, no matter how good you are, is because the extreme heat required will very easily destroy the brushes and the brush holder. It's for the same reason they tell us not to run the drill motors at their stall point. Sure, you can use a heatsink and blah blah blah blah blah... but why take the chance?
Shadownight: just because something wasn't illegal when you did it doesnt matter. Illegal means exactly that. Illegal. For example, team 68's robot last year was legal for awhile, then FIRST declared it illegal. They didnt try and put it out on the field and use it, because they knew it was illegal, even though it was legal when made.
I do agree that FIRST probably wont care if you already desoldered them and you redo the job, but that general philosophy isn't too great.
Also, new drill motors are only like 28 bucks. it might be a worthy investment, both to conform to the rules (if FIRST doesnt allow you to use your current ones) and to have as spares.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 09-02-2004, 19:52
That would matter if it was illegal, but its not, see above.
Unread 09-02-2004, 19:55
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
Ummmm... we ran ours, and our clamp broke free, the wires hit the table and flew off..... can we use solderless in this case?
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Cory's Avatar
AKA: Cory McBride
Joe: that question was answered on the 5th, the update was put out on the 6th. Im inclined to believe the update, especially when it says
"You may not replace the blue wires, however, you may shorten them such that there is
their cut ends. Do not attempt to unsolder the blue wires"
Cory
2001-2004: Team 100
Unread 09-02-2004, 20:01
does anyone know for sure about replacement motors? I would be REALLY surprized if you purchase just the motor and it came with those same blue wires.
Unread 09-02-2004, 20:03
however, FIRST had been answering questions with that answer since January 26th. Thus, the not illegal part was already a clarification of their policy.
If someone were to ask that question again, I would strongly assume they would get the same answer. However, if someone wants to do it, they should ask that question again.
Ken, if you order the motors from MMH, they will have the blue wires, since they are just a distributor for FIRST. I do not know if they come with the blue wires if you order them directly from Bosch, but I would guess so also. Remember, it is small wire, but with very high rated insulation.
Unread 09-02-2004, 20:55
I phrased my previous post somewhat badly, and for that I apologize. We followed the rules as we read them. Dean said that this year we're to use common sense in order to interpret the rules, following the spirit and not so much the letter of the law. It was asked in the Q and A if we could do what we did and it was confirmed at that time that we could re-solder the wires on. I will ask again and if we were in error, I will personally fork over the money to purchase new drill motors and will personally re-install them. However, I still do not believe that we were in error and that we are following the rules as designated by FIRST.
On a side note, I did not intend to indicate in anyway that it's ok to re-solder the drill motors simply because inspectors would have a hard time telling the difference and would probably pass by inspection. Doing such an act would violate the spirit of FIRST and would be wrong.
