Re: back-driveable vs. not
we used the window motors last year for our fold out pushing arms that weighed 5 lbs+ each. they were place and the bottoms of the arms. we had to reaplace them several times because the load stripped the gearbox.
aye, we also are using the window motors...a combination of 2 actually because we have the weight and we can...less strain on each motor and all...and after running some of the claculations, we can lift approximately 600 pounds with the motors in combination with gearing down the motors. So yeah...that eliminates the need what so ever to build a devise that prevents the motors from back driving and we really have no worries about breaking the worm gear, especially after some of the testimonials afore mentioned.
If you simply need to keep a platform raised, or something to the effect of that, you might consider keeping a motor running just enough so the torque holds it in place, but does not change the position of said platform, etc.
Just be mindful and use the correct diameter cable (if you are using cable). There is a definite working strength with cable, and it depends quite a lot on how you fasten it and the radius of the attachment used for the cable or whatever diameter pulleys are used. Leave a reasonable safety margin.
A 3/16 inch cable could be used with plenty of safety margin, or you could snap a cable of 1/8 inch or much larger if you don't engineer it correctly. If you have a cable running around a 1/4 inch bolt or something small, do you realize what stress that causes on the cable? Anything less than a couple of inches diameter should be carefully considered, even if you are oly lifting the robot a few times in the course of competition. Do be careful! |
| What if FIRST changed back to 2 coaches? | D.J. Fluck | General Forum | 45 | 08-01-2007 18:25 |
| When do you (HS Students/College Students) go back to school? | D.J. Fluck | Chit-Chat | 58 | 03-09-2002 12:14 |
| What is it that brings you back each year?? | Amy_ComBBAT | General Forum | 10 | 04-05-2002 16:31 |
| Good or bad: back wheels coming off the ground | Gui Cavalcanti | Technical Discussion | 2 | 17-03-2002 22:09 |
| Taking the kits from Manchester on planes back to home base | Ken Leung | General Forum | 4 | 24-09-2001 22:47 |
