Purchasing double solenoids
We have been looking to buy some doulbe solenoids so we don't have to destroy last year's bot for them. The best offer we got so far is $95 and that is too much. Does anyone know where we can get some cheaper?
Re: Purchasing double solenoids
as far as I was aware, you can ONLY use this years solenoids, or solenoids from previous years, so buying new ones is probably illegal. if you were buying new ones to put in last years robot, however, then graverobbing the old ones for this years, then your probably straight.
To be specific:
Call motion industries (there should be a local branch in you area).
The part number of the SMC double solenoid is SY3240-6LOU (I am not sure what the part number for the base is), we purchased ours for ~ $65 a piece. Hope this helps. |
SMC is out of stock on the current double solenoid valve, does anyone know where we can get an alternative supplier? Is there another valve that does the same thing that is available? There is a couple week wait for parts from Japan! Anyone got any ideas? |
#7
yeah SMC is out til sometime in april from what I hear....though there is an upside....go find an equivalent in another company (yes it is legal check the Q & A) and get an equivalent double solenoid from them....
#8
Have you checked the availability of other option selections of the same model? There are many different configurations available, some of which are more common than others. The SY3240-6Mxxx might be available, while the 6L might not be, and the only difference is the orientation of the electrical connections.
I suggest you try to find help with your local distributor, at this point. Talk to them, tell them about robotics, and see if they can help you find what you need. Bill and I just ordered some, yesterday, UPS RED from Indianapolis. |
#9
Here's what we worked out with our local SMC rep (HPE Automation in Deerfield Beach, FL - talk to Julie at 954-429-9560) when we found the others were not available:
SY3220-6LOZ-N7 ($69.45 each including the connectors) I just talked to her, she said there are about 40 left in the country This is body mounted using 2 M3 screws (or tie wraps), the N7 adds no. 4 QD fittings to the top for ports A and B, they need to order the connectors separately from Atlanta (if you don't need them it saves you a few bucks - same connector as other SMC valves), and you'll need to add a 10-32 straight thread to no. 4 QD fitting to the supply side (available from McMaster Carr - this fits fine in the metric port). It makes a nice flat package - it's basically the same as the 3240 (which is base mounted) in the kit except for the port locations and it already has QD's. Last edited by Gary Dillard : 24-02-2004 at 13:28. |
#10
we bought double solenoids this year and WOW!!! they are expensive... we got them for $75.00 a piece!
#11
Talk to Biff. He got us the solenoids we used in our bot (they also have a nuetural position, meaning you can do multi-pos pneumatics easy)
#12
Just a note on Astronouth's comment aboout multi position pneumatics with the center position, be careful what three position (double solenoid) valves you get.
Some, like the ones that came in the kit are all ports blocked in the center position, others are all ports open (except the line in, of course) meaning in the center position all the air pressure from both ends of the cylinder would be released. |
| FIRST Double Jeopardy! (8/27) | EddieMcD | Games/Trivia | 2 | 28-08-2003 21:41 |
| Double Solenoids - assembly. | Frank(Aflak) | Pneumatics | 9 | 06-02-2003 20:33 |
| solenoids from last year | Antonio | Pneumatics | 6 | 29-01-2003 22:59 |
| Rookie Question. double solenoids... | archiver | 2001 | 2 | 24-06-2002 00:57 |
| Solenoids | archiver | 2001 | 9 | 23-06-2002 23:47 |
