Go to Post As goes with all of my advice on CD, try it yourself and make up your own mind. I'm just suggesting things based on experience. See what works for your team. Follow my suggestions to the letter, mix and match them, or even throw them completely out the window. It's all about you and your team. - DampRobot [more]
Unread 09-02-2004, 23:08
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: update 8 clarification, drill motor and blue wires
Originally Posted by KenWittlief
does anyone know for sure about replacement motors? I would be REALLY surprized if you purchase just the motor and it came with those same blue wires.
I bought motors right from Bosch. They come with the blue wires.
Joe J.
Unread 09-02-2004, 23:26
philipprogramer philipprogramer is offline
#0762 (Patriots)
Team Role: Operator
philipprogramer is an unknown quantity at this point
ok, i'm still in the dark... Is it legal or not to desolder the wires, first they say it isn't then it is now i'm confused
Team 762
1st Seed UCF 2003
7th Seed UCF 2004
Quater-finalists (thanks 312 and 59)
GM Industrial Design Judge's Award UCF 2004
ANYTHING is Possible
Unread 09-02-2004, 23:53
fox46's Avatar
fox46 fox46 is offline
FRC #2013 (Cybergnomes)
fox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond reputefox46 has a reputation beyond repute
Ahem.. Um....well.. you see, they sorta- "desoldered" themselves... We were running ours, and they melted the solder and fell off, so we've been using our own solderless connectors- what would be the ruling on this? Should we risk destroying our motors by resoldering them? Personally I would consider using the stock blue wires FIRE AND SAFETY HAZARDS As the can get extremely hot. 12Gauge wire will NOT handle 40 Amps of current!! This seems a little "non-engineer like" of FIRST,
Mentor, Team 2013 Cybergnomes 2010 - 2014, 2016
Mentor, Team 3756 RamFerno 2011 - 2013
Mentor, Team 854 Iron Bears 2005-2007
Founding member, Team 854 Iron Bears 2000-2005
Mech.Eng.+Mgt University of Ontario 2009
B.Ed OCT Trent University 2015
Professional Education and Product Knowledge Consultant - Toyota Canada Inc.
Unread 10-02-2004, 00:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Just like 50 Amp battery connectors will not handle the 120 amps that can pass through the breaker.
Unread 10-02-2004, 05:48
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Do a little search. There are discussions about how the blue wires will carry the current of the motors. The wires I believe are designed differntly from normal gauge wire. Also if you wires are desoldering themselves then you have more serious problems then those two wires falling off. The drill motors possibly may be damaged internally. They never got that hot for our team.
Unread 11-02-2004, 01:21
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
FIRST really made a mess when they titled that paragraph 'Caution advised regarding the ½” drill motors.'
They then proceed to say "You may not replace the blue wires," and "Do not attempt to unsolder the blue wires".
Is it a cautionary advisory, or a rule?
All the QA has been that it is a strong advisory, but I guess the next update will clairify.
Wetzel
Do, or do not. There is no try.
Unread 12-02-2004, 18:01
Dorsk65's Avatar
Dorsk65 Dorsk65 is offline
Robots first,Sleep second
AKA: Robert Bloom
#0833
Team Role: Student
Dorsk65 is an unknown quantity at this point
Last year we de-soldered the wires from both the motors (I'm not sure why, the originals should have handled) and came out with one working motor and one horribly screwed up one. I can't really describe the problem, but it was definitely because of the soldering, so I strongly reccommend avoiding soldering the wires back on.
"It won't work." (or something to that effect)
-Our always optimistic leaders
Unread 13-02-2004, 01:12
Andy A. Andy A. is offline
Getting old
FRC #0095
It seems to me, a better option then soldering/desoldering would be to just take the blue wires off, file off the exsisting solder and use some crip on connectors. You avoid high heat so there is no way you can kill the motor, you eliminate the 12 gauge (yes, i know the insulation is rated high, but still...) and you keep everything on easy to swap quick disconnects.
I realize, that if the update is to be taken as a rule, this is illegal. However, if FIRST had meant this to be a rule, it would have been put into the manual through the team update. Instead, it was issued as an advisory.
My take on it is thus: You may do what ever you please to the wires short of replacing them with smaller wires. However, you have been warned, and don't expect FIRST to be sympathetic when you complain about the new motors not being robust.
I plan on testing some crimp on connectors on last years drill motors. Assuming I can get the solder off with out trouble and the connections are good, I'll consider doing the same on this years motors. Unless some one can convince me that FIRST is going to consider that advisory a rule, it seems the best route to go.
-Andy A.
Unread 13-02-2004, 07:26
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
On the FIRST Q&A System, there have been many, many (did I say many) questions regarding the blue wires and the update. Many teams had already altered their blue wires by shortening them, removing them, resoldering them, and/or replacing them with quick connects. Most of them asked if the motors would pass inspection since they were altered prior to the update.
In ALL instances, FIRST says that these teams will still be in compliance with the rules but that such alterations to the blue wires are not recommended.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
