Go to Post me: "Was I on fire!?" Roberto: "Sure you were. We only let you burn for about 10 seconds.":yikes: - El Geffe [more]
Unread 09-02-2004, 23:19
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Long Wiring
I was wondering if any teams/individuals have ideas on how to wire 2 motors that are at the top of a telescoping arm. It'd be great if anyone could offer advice/techniques on stealthily wiring 4 wires to attach to the outside of 2 alunimum tubes, that extend approx. 5-7 feet, without having a mess of wire in a certain place.
It's been a long day, so my wording might be a little off, hehe. My team has until Friday/Saturday to get everything finished (basically there), so we're kinda in a rush now.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Unread 09-02-2004, 23:23
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: Long Wiring
I'd have to know more about the situation, but you might look into drilling a hole large enough to snake the wires through the inside of the tube. If you decide to do this, make sure that you protect the wire around sharp edges, or even do away with the sharp edges by filing. The helical wire wrapping material is very handy, but if you don't secure it, you should check it regularly to make sure that it stays in the right place.
If you could post a picture of the situation, it'd be a lot easier to suggest ways of helping.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 09-02-2004, 23:25
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
Re: Long Wiring
Well currently I don't have any pictures of it (my team never releases pictures until our first regional anyway). Also, we cannot wire it through the tube, because it's square 1/4" aluminum, 1 inside the other.
Unread 10-02-2004, 00:01
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Re: Long Wiring
what's so bad about ziptying the wires to the arm? like on the outside...I imagine that there really isn't any other way for you to do it.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 10-02-2004, 00:17
pras870's Avatar
AKA: Mike
#0870 (Team Rice)
Re: Long Wiring
I thought about this, but that would mean that there would be a bunch of wire when it compresses.
I attached an image of what it will look like in a before/after extension. Now The wire cannot be attached inside the tubing, because there is no space between the 2 tubes, and there is a shaft inside the middle which we do not want to get entangled.
Unread 10-02-2004, 00:24
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
Re: Long Wiring
we had this problem in 2001 when we had a long telescoping arm. we fixed it in a jury rig kind of way, but it worked.
we took a long piece of surgical tubing and affixed our wiring to it at regular intervals. for example, if the wiring was tied off at every 3 inches of surgical tubing, then between each tie off there would be 6 inches of wiring. in its normal state, the wiring kinda zig-zagged back and forth. when the arm extended, the tube stretched so that at full extension the wiring was going straight with the tubing.
this is a great, if brute force, way of controlling wiring. there is always a chance of entangling the wiring in an external object, so you may want keep it in some sort of flexible sleeve on the side of your arm.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 10-02-2004, 09:05
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Long Wiring
Solace is correct, Using rubber tubing or even rubber bands you can keep the wire under control. Start with things at max length, Then figure what you can tie to that doesn't move and tie the strechy things in center of wire loops you want to control. Good luck
Threads getting too long to make sense of Ken Leung CD Forum Support 22 05-05-2005 01:14
Q&A Discuss: How long is the bump from the ramp to the top? CD47-Bot Extra Discussion 1 11-01-2003 09:48
How long have you been with your team? D.J. Fluck General Forum 39 17-07-2002 14:30
Hits, Misses, & Suggestions -- long message archiver 2000 17 23-06-2002 23:36
How long should production time be??? archiver 1999 4 23-06-2002 23:16
