Go to Post Repeat after me: "The Internet is my friend." :rolleyes: - Bill Moore [more]
Go Back   Chief Delphi > Other > Math and Science
  #46   Spotlight this post!
Unread 09-02-2004, 19:09
OldDan1168 OldDan1168 is offline
Webmaster, Witty Writer
#1168 (MalvernCTDI Friarbots)
Team Role: Webmaster
OldDan1168 is an unknown quantity at this point
Re: .999~ = 1
Hi guys,
never posted before because i'm afraid i'm not as technically proficient with FIRST robotics as a lot of you, but, if there's one thing i know, it's calculus.
.999~ (.999 recurring or repeating as its commonly known) does in fact equal one. The "Multiply by Ten" Proof is true, but difficult to grasp for the common mind, so suffice to say that this proves it once and for all: (granted someone already did mention this)
A infinite geometric series is a series of numbers where one begins with a set point (the First element) and finds the next point by multiplying the First element by some number X. Then, to find the next number in the sequence, you keep on taking the number you have and multiplying by X (X is called the common ratio, in fact). Odd as it may seem, such infinite series of numbers do in fact add up to definite finite real values. The sum of an infinite geometric series is A / (1 - R) where A is the First element of the series and R is the common ratio. In this case, The series is .9 + .09 + .009 + . 0009 ad infinitum. Thus, the First element "A" is clearly .9 and the Common Ratio "R" is clearly .1 , or One-Tenth. Now, consider: in this case, A / (1 - R) = .9 / (1 - .1) which equals .9/.9 which of course equals 1. Ta da! For those of you who don't believe this geometric series sum rule i am using, there are myriad other ways to show the fact, such as the calculus' Ratio test, etc.
Meanwhile, this is a fascinating discussion, and I enjoyed reading everyone's thoughts. Someone mentioned the idea of 0/0. There's a name for it, and I seem to forget exactly what the name is (the name does make sense once you hear it). Anyway it's not 0; 0/0 is equal to INF/INF or 1^INF or 0^0 or any other myriad devilish expressions : it simply does not exist. I think it might be called an infinite discontinuity but that's just a guess. anyhow, there's math for ya!
captain dan
team 1168
www.friarbot.com rocks my world too hard
  #47   Spotlight this post!
Unread 09-02-2004, 19:42
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: .999~ = 1
note - only for R < 1.
One of the best known applications of this is L'Hopital's rule, which is used for finding the integrals of certain functions that can be transformed into something that resembles one of those patterns - 0/0, inf/inf, inf-inf, 1^inf, 0^0, et cetera.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
  #48   Spotlight this post!
Unread 10-02-2004, 02:12
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Re: .999~ = 1
L'Hopital's Rule is actually usually used for computing limits. For example, to compute
lim x/sin(x) as x-->0, we can apply L'Hopitals rule to find that
lim x/sin(x) = lim 1/cos x = 1.
  #49   Spotlight this post!
Unread 10-02-2004, 10:09
mtrawls's Avatar
mtrawls mtrawls is offline
I am JVN! (John von Neumann)
#0122 (NASA Knights)
mtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to beholdmtrawls is a splendid one to behold
Send a message via AIM to mtrawls
Re: .999~ = 1
I believe you are looking for "indeterminate form." Check out mathworld
  #50   Spotlight this post!
Unread 10-02-2004, 11:04
Computer Guy
AKA: Dav
Re: .999~ = 1
also thus used in calculus for finding the limits of infinite integrals (happened to be doing that a couple of days ago in calculus, so I mentioned it in that context).
  #51   Spotlight this post!
Unread 24-02-2004, 09:55
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Re: .999~ = 1
a couple of things
Firstly:
i can prove that 1=0
ok, assume its an identity (cant do that on a keyboard but assume the = is an identity sign)
if you say 1=0
if you take 1 from each side
0=-1
multiply by 2
0=-2
add one to both sides
1=-1
Square
1=1
voila
or do it backwards to get it if you like.
also, i can prove mathamatically the first part
1/9 = 0.1111... (recurring)
10/9 = 1.1111... (recurring)
10/9 - 1/9 = 9/9 = 0.9999999999, or 1 as 9/9 is 1 but 9 x 0.11111111111 = 0.9 revcurring. therefore 0.9999.... doesn't exist
its marvalous that e^(pi i )=-1
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
  #52   Spotlight this post!
Unread 25-02-2004, 11:40
Computer Guy
AKA: Dav
Re: .999~ = 1
Originally Posted by Denman
a couple of things
Firstly:
if you say 1=0
0=-1
multiply by 2
0=-2
1=-1
Square
1=1
voila
squaring is not a 1 to 1 operation, thus you cannot do the proof backwards, and thus it is not valid.
x^2 = y^2 --/--> x = y
(x squared = y squared) does not imply (x = y)
  #53   Spotlight this post!
Unread 25-02-2004, 11:52
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: .999~ = 1
You can't get the square root of 1 equal to -1 so it fails.
  #54   Spotlight this post!
Unread 25-02-2004, 11:58
AKA: Nelson Green
Re: .999~ = 1
hence definitively reversible. also known as not being one-to-one, as you said. Essentially, the inverse function is not actually a function. it's all good
At least when it is not defined. arccos x is defined from 0 to 1 and arcsin x from -pi/2 to pi/2. This makes it one to one and gives it an inverse function.
  #55   Spotlight this post!
Unread 25-02-2004, 11:59
Ben Lauer's Avatar
Ben Lauer Ben Lauer is offline
Seshambeh Dareh Meyod
Ben Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond reputeBen Lauer has a reputation beyond repute
Re: .999~ = 1
Originally Posted by n00b
major probelm: you cannot take the ln of a negative number. therefore, the term ln e^(i * pi) cannot exist. i have another one of those phony proofs, its kinda fun:
let a=1, b=1
a = a
a^2 = ab
a^2 - b^2 = ab - b^2
(a + b)(a - b) = b(a - b)
a + b = b
1 + 1 = 1
have fun =D
can't divide by zero....3rd to last step
  #56   Spotlight this post!
Unread 26-02-2004, 06:23
Denman's Avatar
AKA: Stephen Denman
Re: .999~ = 1
at least someone found the correct reason for it being incorrect
What is the sqrt of 1?
Consider that if you square -1 you get 1 and so the sqrt of 1 is -1 or 1
  #57   Spotlight this post!
Unread 02-03-2004, 16:34
AKA: Nelson Green
Re: .999~ = 1
Anyone want to help me with this one?
Find the fallacy in the following argument that 0 = 1.
dv = dx --> v = Integral (dx) = x
u = 1/x --> du = -1/(x squared) dx
0 + Integral (dx/x) = (1/x)(x) - Integral ((-1/(x squared)(x)) dx = 1 + Integral (dx/x)
So, 0 = 1
It is integration by parts ( integral (u dv) = uv - integral (v du)). I should be figuring it out myself but when I saw the problem I thought of all of you.
  #58   Spotlight this post!
Unread 02-03-2004, 17:16
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Re: .999~ = 1
Given that you're working with reals, it's true that you can square a negative number, but the square root function only outputs positive numbers.
sqrt(1) /= 1 or -1
+/-1^2 = 1
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
  #59   Spotlight this post!
Unread 02-03-2004, 20:42
Computer Guy
AKA: Dav
Re: .999~ = 1
So, 0 = 1
constant of integration.
  #60   Spotlight this post!
Unread 03-03-2004, 15:03
Dejhan_Tulip Dejhan_Tulip is offline
Dejhan_Tulip has a little shameless behaviour in the past
Talking Re: .999~ = 1
Everyone's proving stuff...
Well... 2 = 1
Why ??
Check this out... nothing illegal and you can go backwards
a = b
ab = b^2
ab - a^2 = b^2 - a^2
a(b-a) = (b-a)*(b+a)
a = b+a
So if a=1, b=1 too (since the first thing I assumed was a = b )
1 = 1+1 ???
Have fun...
Don't flame... I am putting this to have some fun
