Go to Post Seating is limited. Be sure to apply deodorant and brush your teeth. - Wayne TenBrink [more]
Unread 09-02-2004, 22:40
occra 23.
AKA: ryo
None #1481
umm.. heat sinks. sorry, we're roookies.....
i've looked around and saw a lot about heat sinks but not much about how to mount(stick? clasp?) them to a motor. zip ties, super glue, bolting um on? all i know is that they should be smack against the metal right? like metal against metal.
does it even matter what we use to mount it?
is glue a bad idea? (i'd think hot glue is a bad idea because of its low melting temp)
how about tape? the athletic taping tape? whatever you call it. the ones that stretch but let air through.
Unread 09-02-2004, 22:51
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: umm.. heat sinks. sorry, we're roookies.....
Zip ties worked well for us. The RC car heat sinks are a little small and we actually fractured ours to get them to fit. The metal is partially cracked but not broken.
Unread 09-02-2004, 22:56
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
ziptties will work...glue is bad...those motors WILL heat up, a LOT...last year they leads goign from the pwms to the motors desoldered themselves, that's how hot the motor got...and glue has a much lower heat tolerance than solder, plus it could theoritically catch fire or it could get inside the motor and that's the end of that motor...some teams have used the exterior of a soda can to make heatsinks...and zipttie it on. Other teams have welded together aluminum heatsinks and made them so that they "clasp" on shut to the motors.
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
If it's going to have any hope of working, you need to have something thermally conductive between the heatsink and the motor. If you have another method for securing the heatsink to the motor, buy a packet of heatsink compound from your local Fry's or Radio Shack.
If you want to take care of it all at once, you can use thermal epoxy.
Here's a link to some cheap epoxy:
Thermal Epoxy
If you want it to be non-permanent, mix up the epoxy, then mix in about 33-50% plain old heatsink compound.
Chances are any heatsink compound is a bit of overkill, but if you are actually needing to worry about heatsinks, then you might as well make sure they work as well as possible, and it doesn't cost that much.
If we're worrying about extreme heat, Artic Alumina Thermal Adhesive says it's rated to over 150C I'd be worried about a motor that got hotter than that.
Arctic Alumina
Unread 10-02-2004, 10:00
what kind of drive train are you using? how low is your transmission geared down?
ifyou are using either of the FIRST transmissions and you have the drill motors in low gear, and you have a two wheel drive set up (with skid plates or castors) then you will not need to put heatsinks on the drill motors.
they have blowers built into them, and as long as you dont block the openings next to the brushes, they will cool themselves.
the problem with heatsinks is, if your motors are getting so hot that you think you need them, you are destroying your motors and the heatsinks wont really help anyway. The reason is the current in the motor flows through the windings, which are on the armature in the center of the motor - the part that spins. The outside of the motor is only the magnets - so if the armature is getting so hot that the magnets are cooking, imagine how hot the windings are.
and when you put a heatsink on, what are you makeing contact with???? the metal case around the magnets - not the armature - so all you are doing is cooling the magnets down, and not providing any additional cooling to the windings - the part that WILL fail when it gets too hot (the insulation will bake off the wires, or the silver solder holding the wires to the commutator will melt.
Robots usually dont cook their drive motors unless they are geared up too high, or they are using tank treads, or 4WD with front wheels that dont slide sideways very easily. And even then, if you have your bot geared down enough (say 3 feet per second) then the motors will still be able to spin fast and keep themselves cool - on the windings, where it counts.
Unread 10-02-2004, 11:36
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Never use 'em...
Originally Posted by KenWittlief
...the problem with heatsinks is, if your motors are getting so hot that you think you need them, you are destroying your motors and the heatsinks wont really help anyway. ...
I am with Ken on this one. 9 years in FIRST and we have never used them. We have cooked a fair number of motors in our day, but I doubt that any heat sinks would have helped.
I think it is better to pick the right motor(s) for the job and then gear them right than to bother with heat sinking them.
Joe J.
Unread 10-02-2004, 11:58
someone else pointed out in another thread on heatsinks, if you are in the elim rounds and you REALLY want to cool your motors between matches then instead of using heatsinks
you can buy spray cans of component cooler (try radio shack). it use to be freon but now its something else - and you can blast your motors with it and get them icy cold for the next match
cool (pun!) thing about this, with the drill motors you can spray it inside the motor, where it needs it the most.
but there is another aspect to hot motors that everyone must keep in mind. When you play at the events the matches are 120 seconds long - no much time really
but before you ship your bot your team is going to want to practice practice practice with it for hours at a time
its best to design your drivetrain so it can be driven for hours without heating up - this will also mean you are not sucking your bats dead in a manner of minutes either - A well designed machine will only required a large amount of power when it is pushing or dragging something heavy - just driving around, collecting balls, steering around the field, should not require much power - if it does, your robot is fighting against itself.
Unread 10-02-2004, 12:22
Cooling the motor too fast is bad for the magnets and can crack the brushes rendering it useless. A light bit of spray on the outside is okay but I never get them too cold.
Unread 10-02-2004, 12:29
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
we've never used heatsinks per se (although i guess you could argue that our mounting brackets have doubled as heat inks in the past). what we usually do is mount small muffin fans directly under the motors. if you drill holes in the floor of your bot directly under the muffin fan, it will suck the colder air up from outside the bot and directly into the motor. works pretty well, we never tripped our breakers last year even though we had a high speed bot (12 ft/sec) with a grossly inefficient turning process.
oh, and by the way, although gearing your bot to lower speeds like 3 ft/sec will definitely solve your overheating problems, you will be far too slow to actually compete in the game.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 10-02-2004, 15:26
occra 23.
AKA: ryo
None #1481
yeah... thanks everyone, I'm not worried about overheating yet. cuz we ahven't even finished the drivetrain yet. we reeaally need to work on it. I was just wondering. and if we have time, wouldn't having heatsinks be better than not having them even if we don't need them? unless we cover the openings (drill motor), is there a possibility its a bad idea to have them on?
you know, the " better safe than sorry" thing
Unread 10-02-2004, 15:31
Alavinus's Avatar
Alavinus Alavinus is offline
Siege Weapon/Robotics Guy
AKA: Andrew LaVinus
Alavinus will become famous soon enoughAlavinus will become famous soon enough
Send a message via AIM to Alavinus
A better option then the heat sinks would be to use the small muffin fans found in the KOP. They require less machining, cost less, and get the air to where it is needed. (The inside of the motor) The fans can be zip-tied on and will aid in cooling.
Of course in your'e really worried about heat, there are always those other fans in the kit...
Unread 10-02-2004, 16:38
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
We've never had hinksinks, nor had any problems attributed to overheating.
We've always been to close to being overweight to worry about it.
Question: Whats the best way to cool most motors, like the drill motors we have?
Answer: Run them full speed at no load.
If you run the drill, you will notice a draft from them. They are designed such that they will such air in and air cool the windings and other hot things. This is then exhasted (the draft) out the back. Cover those, and you will likely overheat and get nice baked motors. Leave them clear and don't worry about heatsinks.
Wetzel
Unread 10-02-2004, 16:44
occra 23.
AKA: ryo
None #1481
just one more question. do the drill motors suck in air going in reverse too?
Unread 10-02-2004, 16:46
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
you can drill a hole on the bottom of then and mount them with screws....:/
Unread 10-02-2004, 16:48
yes, the blower is not directional - it works on centrifical force
it would be good for every team to take a burnt out motor, or one you are not using (like the fisherprice motors) and disassemble it and glue it to a piece of lexan or something
so that new students can see whats inside it, and get an intuitive sense of how it works, instead of it being a metal can with two wires coming out.
BTW - when you really cook a motor you will know - it has a lingering nasty smell, a little bit like varnish or shellac - and once you cook it the smell never goes away, it will always stink.
Heat Sinks for Drill motors JL Clifford Motors 9 15-01-2004 18:46
'IT' info... archiver 2001 19 24-06-2002 01:58
heat sinks archiver 2000 1 23-06-2002 22:45
Heat sinks Tech Fusion Off-Season Events 2 11-11-2001 19:57
heat gun Lake Orion OCCRA 2 21-10-2001 23:34
