Go to Post FIRST is the most glorious test of the mind. Anyone can run a marathon or get a slam-dunk. It takes guts to admit you are a nerd that enjoys six weeks off non-stop stress, and actually thrives on it. - kws4000 [more]
Unread 09-02-2004, 16:10
Robert Hafner's Avatar
Robert Hafner Robert Hafner is offline
FIRST Alumni
Robert Hafner is on a distinguished road
Send a message via AIM to Robert Hafner Send a message via MSN to Robert Hafner Send a message via Yahoo to Robert Hafner
put and get
the putdata function updates the pwms right?
<-- LEGO Guy amuses me. (notes that since LEGO isn't capitalized on the smilie bar LEGO Systems, Inc. would not be pleased. . . )<-- off topic.
Unread 09-02-2004, 16:59
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Re: put and get
Yes, that's what I understand. Except for pwm's 13, 14, 15 & 16, which are updated by Generate_Pwms:
void Process_Data_From_Master_uP(void)
  Getdata(&rxdata);   /* Get fresh data from the master microprocessor. */
  Default_Routine();  /* Optional.  See below. */
  /* Add your own code here. */
  printf("Port1 Y %3d, X %3d, Fire %d, Top %d\n",(int)p1_y,(int)p1_x,(int)p1_sw_trig,(int)p1_sw_top);  /* printf EXAMPLE */
  Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
  Putdata(&txdata);              /* DO NOT CHANGE! */
Unread 10-02-2004, 01:57
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
Re: put and get
Putdata also updates the data that is sent back over the radio to the OI dashboard port and LEDs. Basically it updates the data on the master to reflect the changes in the txdata variable by the user.
Unread 10-02-2004, 08:54
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: put and get
It only actually updates the PWMs every 26.2ms. You can call it more often, but it won't do anything.
Unread 10-02-2004, 10:58
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: put and get
basically, it updates what the master processor is "seeing" from the user processor. every 26.2ms, the master processor takes a snapshot of this and uses it to update the PWMs, et cetera.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Get Ready to DUEL! MOEWidow Off-Season Events 40 15-10-2003 21:16
Interfacing a second Micro to the RC Matt Reiland Programming 3 08-06-2003 00:11
Large Multiplication.. randomperson Programming 7 31-12-2002 19:29
Hits, Misses, & Suggestions -- long message archiver 2000 17 23-06-2002 23:36
Best Wheel Grip? archiver 2001 20 23-06-2002 22:38
