Go to Post Rain? Prepare for Armageddon to strike when you go to St. Louis. Two years in St. Louis. Two years of Tornado scares. Tis the season. - Koko Ed [more]
Unread 10-02-2004, 12:04
Zaramel2002 Zaramel2002 is offline
#0963 (Tiger Techs)
Zaramel2002 is an unknown quantity at this point
Send a message via AIM to Zaramel2002
how to add sevral steps to an encoder autonomous program
I was wondering how to make the program below count the encoder then go to another step instead of ending.
Im trying to make this code my encoder program for this years robot please help.
int encoder_count = 0;
short start_counting = 0;
short end_program = 0;
void Default_Routine(void) /* default routine */
if((end_program != 1) && (encoder_count < 12))
/* if program has not ended
and encoder has registered
less than 20 ticks */
pwm01=pwm03=169; /* turn left motors forward slowly */
pwm02=pwm04=86; /* turn right motors forward slowly */
if((end_program != 2) && (encoder_count < 30))
if((start_counting == 1) && (rc_dig_in08 == 0))
/* if sensor has seen light and now sees dark*/
encoder_count++; /* increment encoder count */
start_counting = 0; /* set to 0 to prevent program
from counting wedge or spoke more than once. */
if(rc_dig_in08 != 0) /* if sensor sees light */
start_counting = 1; /* set to 1 to enable program
to count a dark wedge or spoke */
else
pwm01=pwm02=pwm03=pwm04=127; /* stop */
end_program = 1; /* end program */
printf("%d\n" , rc_dig_in08 ); /* print IR Reflective Sensor readings */
} /* END Default_Routine(); */
Unread 10-02-2004, 21:45
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: how to add sevral steps to an encoder autonomous program
Originally Posted by Zaramel2002
I was wondering if I could modify the code that is on usfirst.org to do multiple steps after the if statement .
 if (1)
  step1();
  step2();
  step3();
  etc();
Unread 11-02-2004, 07:34
AKA: Jamie Bliss
I use a static and a loop (in this case, Count is incremented by the sub, but is easily modifiable for ticks)
void Auto(void)
 static long Count = 0;
 if (Count >= 100) //Example, highest first
  //Step 5
  count=0
 else if (Count >= 80) //Example
  //Step 4
 else if (Count >= 60) //Example
  //Step 3
 else if (Count >= 40) //Example
  //Step 2
 else if (Count >= 20) //Example
  //Step 1
 Count = Count + 1;
} //End Auto()
Unread 11-02-2004, 08:35
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
void Auto(void)
//Step 5
count=0
//Step 4
//Step 3
//Step 2
//Step 1
Count = Count + 1;
} //End Auto()
Nice example.
Linux: steps to program fullsize RC robot rwaliany Programming 31 14-02-2004 14:45
Aspartame shyra1353 Chit-Chat 8 20-01-2004 22:41
Anyone looking for more program space? archiver 2001 13 24-06-2002 02:20
