Small problem
When our team got its parts we were not given a 40 amp Maxi Fuse holder! So we improvised and use a "Stinger" car audio maxi fuse holder. But the stinger only holds 2 fuses and we need to run 3 things off of it. What I need to know is 2 things, first can we run victors on a 30 amp breaker to a window motor. Second is our new Maxi Fuse legal, because we arent able to order one that came in the kit because they are back ordered! Thanks
Dan B Team 940 |
Re: Small problem
The answer to your first question is you need to run the window motor to a spike or a speed controller with a 20 amp breaker. The Maxi block is only for the drills and CIMs. Any other motor must run to the standard breaker block.
As to your second question, check the FIRST Q and A site and search around here. The topic has already been discussed. |
| Small Parts orders | archiver | 2001 | 2 | 23-06-2002 23:50 |
| The problem with scouting... | archiver | 2001 | 10 | 23-06-2002 23:49 |
| Small Parts | archiver | 2001 | 8 | 23-06-2002 23:44 |
| Kickoff Workshops......... Small Problem | archiver | 2001 | 3 | 23-06-2002 22:08 |
| Major problem with chipphua motors | aka Scott White | Motors | 18 | 19-03-2002 19:44 |
