Go to Post Part of being an effective leader is knowing your own personal limits. - artdutra04 [more]
Unread 10-02-2004, 16:53
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
Re: umm.. heat sinks. sorry, we're roookies.....
Wow thats a good idea i think ill do that....right..................now.
Im not insain, I'm just...different
Unread 10-02-2004, 17:14
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Originally Posted by KenWittlief
when you really cook a motor you will know - it has a lingering nasty smell, a little bit like varnish or shellac - and once you cook it the smell never goes away, it will always stink.
we really didn't cook our motors last year so much as having the back deform and bad stuff came out of the slots in the back. I remember there being lots of plastic but i could be wrong...I just remember vividly replacing the motors then havign to disassemblle and reaseemble the gearbox because we did something wrong and the gearbox began binding...heat might have added to that too...but then...but regarding the overheating factor, we were running one of our motors in reverse...on a somewhat inneficient 4 wheel drive powered only by 2 drill motors...and I think it's possible that one of the motors vents was blocked so...not the brightest way to build a drive train
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 10-02-2004, 22:30
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Cool in a can...
Originally Posted by sanddrag
Cooling the motor too fast is bad for the magnets and can crack the brushes rendering it useless. A light bit of spray on the outside is okay but I never get them too cold.
We have used the cool in a can stuff for years, freezing the snot out of the motors. While I am sure that it is not particularly good for the motors, we have not had a failure that we trace to this practice in 8 years of competitions.
Joe J.
Unread 10-02-2004, 22:37
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
I bet most people here will agree that rapidly cooling the motors will shorten the life span of the motors.
However, the typical use period is still far shorter then the design life of the motor. My dad has a 20 year old drill thats seen alot of use, and still runs fine.
Point being, yes, it is bad for the motor but it won't matter in the time it is needed to work.
Wetzel
Design to meet criteria, don't worry a whole lot beyond that.
Unread 10-02-2004, 22:52
Some how I doubt you can cool a motor faster by spraying it will a coolant, than it heats up when the motor is stalled and draws a hundred amps for a second or two without spinning
the coolant isnt that powerfull - its not like a magic freeze ray - when you blast it on something in only looks like it has been instantly frozen because dry ice forms on a very thin layer on the surface.
its neat stuff - a powerfull tool when you need it - get a couple cans and experiment with it to get an intuitive feel for how it works - just dont....um....play with it in any way that can be harmfull or dangerous.
Unread 11-02-2004, 19:18
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
One thing that strikes me as dangerous to the motors is that condensation that would develop on something being blasted with that cold air.
Heat Sinks for Drill motors JL Clifford Motors 9 15-01-2004 18:46
'IT' info... archiver 2001 19 24-06-2002 01:58
heat sinks archiver 2000 1 23-06-2002 22:45
Heat sinks Tech Fusion Off-Season Events 2 11-11-2001 19:57
heat gun Lake Orion OCCRA 2 21-10-2001 23:34
