Go to Post The urge to compete tends to drive teams to hold the ideas close during the competition season, but the urge to contribute means they get publicized afterwards. - Alan Anderson [more]
Unread 10-02-2004, 17:07
Jesse Jesse is offline
Jesse is on a distinguished road
Question Mounting the arm
How do you mount an arm on the robot?
Unread 10-02-2004, 17:12
Re: Mounting the arm
connect it to the shoulder?! (is this a trick question?)
remember that you are allowed to make your bot 5 feet tall - I would guess that for most teams, you will want an 'elbow' that attaches to framework just below that height, so your arm pivots from the top of the robot.
for what we need to do this year, you might not want an arm like a human arm, you might want something that looks more like a ladder, that attaches on both sides of the bot and pivots up and down - just a suggestion.
Unread 10-02-2004, 17:16
maybe something like the drawing I posted in this thread?
http://www.chiefdelphi.com/forums/sh...ght=extendable
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
possibly weld it....bolt it......oh i know....DUCT TAPE!!
Actually the best way is to bolt it, that way next year when you want to use that bot as a prototype, you dont have to grind off the weld. makes it alot easier too if something goes wrong and you need to change somethign quickly. Its easier to fix something that is laying down rather that fix something that is 4ft high.
Unread 10-02-2004, 17:41
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Can't use ducktape. Mounting brackets and an axel, a turret style, etc. would work. Chances are you questions would get better answers if you posted them in the right forums too.
Purdue Alumni
Cummins, Inc.
Unread 10-02-2004, 19:17
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
To mount an arm:
Build your robot so you have a plate about 4.5' in the air. Put a brass plain bearing in it. Also put a bearing directly below, around where your motors are. Buy a 5' section of thinwalled steel 1" pipe, put it through the bearings, weld a segment of 5/8" shaft to the top, put bearings on that, and your arm on the bearings. Put a sprocket on the lower part of the steel pipe, drive it with a motor to give yourselves a turret. Fix a sporcket to the welded 5/8" shaft on top, put a gearbox on the arm, chain it to the sprocket.
And your done. Maybe add another segment or two after the first one for a really cool arm.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 10-02-2004, 20:53
Rhs953's Avatar
Revenge is near...
AKA: Mike
#0953 (Illumanati)
I was being "cute" with the word duct tape
anyways i dont think ducttape would be able to hold the amout of torque anyways.
______________________________
I didn't break it!
Unread 10-02-2004, 23:05
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
We welded ours to our frame, not the best idea now that I think about it, but not much we can do about it now. Basically we have one centeral column going up our robot, at the top there is a notched out area, and a hole going throught the side walls. Then we put a bearing and axel in there. The area with the notch is for a movible arm. We just drilled a hole thought that, and placed it on the axel going throught the centeral column. Finally we just hooked up a motor to the base of the centeral column, put cable around it, and attached the other end to the moviable part. And "waaa la", an arm.
I would highly suggest bolting it, just becasue welds are not fun to break.
Unread 10-02-2004, 23:07
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
oh, come on! welds are lots of fun to break, they're just not that much fun to fix.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 10-02-2004, 23:09
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Who needs arms when you've got a..... forklift! Our monster drawer sliders are mounted with two reinforced, shelf, L-brackets that are bolted to the frame and the lift.
Now that i think about it, Our robot may have an additional function as an organizer
Team 1257
Unread 10-02-2004, 23:12
Solace's Avatar
AKA: Jake
and the survey says..................
bubblegum
that's right, we've locked the entire team in the basement for the past 4 weeks so that they can dilligently chew up enough bubblegum to not only attach the arm but to make on the spot repairs at the competitions.
...What is a man,
Jake
Team Paragon #571
Unread 10-02-2004, 23:20
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Mount it 3 ways!
A) Very carefully and acurately - so you don't extend the profile.
B) Very securely - so when you extend it somehow, your robot doesn't break.
C) Very center of gravity-ish - so you don't tip as you retract and/or pivot it!!
That's all I got!
team 314 sweeper arm angier314 Chit-Chat 0 26-03-2003 15:32
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
anyone use an arm to help balance archiver 2001 8 24-06-2002 02:46
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
