Go to Post "One man's trash is our robotics team's fundraiser" (We have an aluminum can drive to raise money) - bombadier337 [more]
Unread 10-02-2004, 17:46
Ryan Dognaux's Avatar
Ryan Dognaux Ryan Dognaux is offline
Back Home in Indiana
FRC #4329 (Lutheran Roboteers)
Ryan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond reputeRyan Dognaux has a reputation beyond repute
Send a message via AIM to Ryan Dognaux
Assistance converting Inventor to 3DS Max
I know, this topic has been addresed, but it's a different situation for us. The computers we are using are using a Novell client networking system, thus screwing our computers up and making them incredibly restricted. For some reason, we can't configure plugin paths, and can't import an inventor file into 3DS Max. Within the next few days or so, we're going to need to put an inventor file into max, and I was wondering if any team would be willing to do me a favor turn the file into a .max extension for me? PM or just leave a message here if you're willing, thanks.
Ryan Dognaux :: Last Name Pronounced 'Doane Yo'
Team 234 Alum: 2002 - 2005 :: Purdue FIRST Member: 2006 - 2009
Team 1646 Mentor: 2007 - 2009 :: Team 357 Mentor: 2009 - 2012
Team 4329 Mentor: Current
STL Off-Season Event: www.gatewayroboticschallenge.com
Unread 10-02-2004, 18:18
Lev's Avatar
Lev Lev is offline
#0116 (Epsilon Delta)
Lev will become famous soon enough
Re: Assistance converting Inventor to 3DS Max
Here is what you do: Export as STL file from Inventor, and then import it in 3dsmax. You'll have to tweak the import settings to get it right, but these should work for most cases:
turn on Autoweld
turn off Auto Normals.
set the smoothing angle somewhere from 10 to 20
Unread 10-02-2004, 19:01
Thanks, I'll try this first. Does this method allow for seperate components with seperate textures?
Unread 10-02-2004, 19:44
Matt Hallock Matt Hallock is offline
#1188 (Oaktown Crewz)
Matt Hallock is on a distinguished road
Send a message via ICQ to Matt Hallock Send a message via AIM to Matt Hallock Send a message via Yahoo to Matt Hallock
Be careful about how programs export their files to other formats. I've run into a few files in 3DSMAX that removes all grouping and makes the object one whole thing, really annoying.
Lead Animator for Donder-Kimball High School, team #1188.
Unread 11-02-2004, 09:08
Tyler Olds Tyler Olds is offline
FUN Show Host
no team (First Updates Now)
Tyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond reputeTyler Olds has a reputation beyond repute
There was another way that I found a long time ago, and is posted I think in 2002. You can actually take the .iam file and put it directly into 3ds max. It had something to do with the plugins, and I am pretty sure that it would work fine even with novell.
I'll try looking for it later if i have time.
First Updates Now Show Host.
Watch and Listen to FUN on Youtube, iTunes, and www.firstupdatesnow.com
FRC Emcee 2009-2016: Team 2826 Wave Robotics Lead Mentor 2001-2004 Team 93 NEW Apple Corps Alumni
CD Moderator
Unread 11-02-2004, 20:44
turn on Autoweld
Tried doing this, but you can't save an assembly file as a .stl file... at least, we don't have that option..? Any suggestions?
Unread 12-02-2004, 17:45
Does anyone have any other suggestions??... because right now we are SOL on this Inventor to 3DS Max thing
Unread 13-02-2004, 00:15
Lev's Avatar
Lev Lev is offline
Does it allow to export as IGES? this also works sometimes, although the results are usually worse than with STL.
Unread 13-02-2004, 06:33
Yes it exports in IGES, but unfortunately this is a pretty complicated piece and thus, when exported as an IGES file it's all one big block that you can't ungroup or anything...
Unread 13-02-2004, 15:19
Lev's Avatar
Lev Lev is offline
Why dont you export it part by part in STL and then assemble the pieces in max?
Unread 13-02-2004, 17:48
That's unrealistic... I'm wanting to import our assembly file of our robot, do you realize how long that would take to import each part file and assemble them?? If it's my only option, I'll do it, but I'd even let someone on another team import the file into a .3ds file before assembling piece by piece. So, if anyone has the capability of turning .iam files into .3ds files and is willing to help us out, just reply or PM me with some contact info.
Thanks
Unread 14-02-2004, 20:51
Lev's Avatar
Lev Lev is offline
Thanks
the only "normal" way of exporting iam files to 3ds is the following:
1) Install Inventor 6 and 3dsmax 5
2) Install autodesk's 3dsmax Inventor Import plugin (search for "inventor" on maxplugins.de
3) Read the manual on how to install it. Its anything but trivial
and then you can import stuff with ease. Sorry, but becasue of the ingenuity of autodesk's version compatibility approach, this is the only combination that seems to work.
Here is my old post in one of the hundred Inventor to Max threads:
As far as i know there is no "export to .3ds" option in Inventor.
But i did find a working plugin for Inventor 6 and 3dsmax5 (and 3dsmax3 and 4 as well) - you can download it here: http://adeskftp.autodesk.com/prodsu..._Max_Plugin.zip (and the installation instructions are found here: http://www.mekvizion.com/Support/Ma...ugin_Readme.txt )
Hope this helps
Unread 14-02-2004, 21:12
Today w/ some help, I imported our robot as a .IGES file into 3DS Max, then converted it to an editable mesh and separated it by selecting each piece by "element" and detaching them. Tedious? A little, but it works fine... if anyone is having major problems w/ plugins and such, I would try doing this... but don't try importing a HUGE file into Max as .IGES, because it can't handle it.
Unread 16-02-2004, 22:22
bolton's Avatar
bolton bolton is offline
AKA: John Bolton
#0610
Team Role: Communications
bolton is an unknown quantity at this point
If you still have a copy of max 5 you can install both that and your copy of inventor on the c drive. you can go into max and under the plugin paths add the Autodesk Inventor folder (I think it's the bin folder you want but not positive). Add the subpaths. next time you boot up max 5 you should be able to import an iam straight in. save it as a max file (or export as 3ds) and open it in your copy of max 6.
Unread 16-02-2004, 22:34
FUN Show Host
IGES files tend to be huge, did your tedious work make it any smaller?? If so I would think that is the best option.
CD Moderator
Bitmaps as texture in 3ds max? BC1022 3D Animation and Competition 3 28-01-2003 18:32
3ds max VS Maya VS XSI DisTurbed 3D Animation and Competition 7 08-08-2002 22:52
Another 3ds max "Key" Jack 3D Animation and Competition 7 09-05-2002 21:19
Text effects in 3DS Max... Ranma 3D Animation and Competition 6 28-02-2002 21:56
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
