Go to Post Neat! I like when things break, it's educational! - s_forbes [more]
Unread 10-02-2004, 19:17
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Re: Mounting the arm
To mount an arm:
Build your robot so you have a plate about 4.5' in the air. Put a brass plain bearing in it. Also put a bearing directly below, around where your motors are. Buy a 5' section of thinwalled steel 1" pipe, put it through the bearings, weld a segment of 5/8" shaft to the top, put bearings on that, and your arm on the bearings. Put a sprocket on the lower part of the steel pipe, drive it with a motor to give yourselves a turret. Fix a sporcket to the welded 5/8" shaft on top, put a gearbox on the arm, chain it to the sprocket.
And your done. Maybe add another segment or two after the first one for a really cool arm.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 10-02-2004, 20:53
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
I was being "cute" with the word duct tape
anyways i dont think ducttape would be able to hold the amout of torque anyways.
______________________________
I didn't break it!
Unread 10-02-2004, 23:05
NateBot16 NateBot16 is offline
#0528 (Dark Knights)
NateBot16 is on a distinguished road
Send a message via AIM to NateBot16
We welded ours to our frame, not the best idea now that I think about it, but not much we can do about it now. Basically we have one centeral column going up our robot, at the top there is a notched out area, and a hole going throught the side walls. Then we put a bearing and axel in there. The area with the notch is for a movible arm. We just drilled a hole thought that, and placed it on the axel going throught the centeral column. Finally we just hooked up a motor to the base of the centeral column, put cable around it, and attached the other end to the moviable part. And "waaa la", an arm.
I would highly suggest bolting it, just becasue welds are not fun to break.
Unread 10-02-2004, 23:07
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
oh, come on! welds are lots of fun to break, they're just not that much fun to fix.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 10-02-2004, 23:09
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Who needs arms when you've got a..... forklift! Our monster drawer sliders are mounted with two reinforced, shelf, L-brackets that are bolted to the frame and the lift.
Now that i think about it, Our robot may have an additional function as an organizer
Team 1257
Unread 10-02-2004, 23:12
Solace's Avatar
AKA: Jake
and the survey says..................
bubblegum
that's right, we've locked the entire team in the basement for the past 4 weeks so that they can dilligently chew up enough bubblegum to not only attach the arm but to make on the spot repairs at the competitions.
...What is a man,
Jake
Team Paragon #571
Unread 10-02-2004, 23:20
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Mount it 3 ways!
A) Very carefully and acurately - so you don't extend the profile.
B) Very securely - so when you extend it somehow, your robot doesn't break.
C) Very center of gravity-ish - so you don't tip as you retract and/or pivot it!!
That's all I got!
team 314 sweeper arm angier314 Chit-Chat 0 26-03-2003 15:32
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
anyone use an arm to help balance archiver 2001 8 24-06-2002 02:46
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
telescoping arm & ten second rule Ben Mitchell Rules/Strategy 4 18-02-2002 21:37
