Go to Post I am really glad that FIRST gives teams the choice to use either students or adults in this role. - dtengineering [more]
Unread 10-02-2004, 19:22
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Piston throw control
I was just wondering if any team had tried to control the amount of throw in a piston, like stoppint it 1/4, 1/2, or 3/4 of the way through it's stroke. I believe it is possible, just like in a hydrolic system on a piece of heavy machinery, but I am having some troubles actually making it happen. If anyone has any ideas I would love to hear them.
Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 10-02-2004, 19:25
Umm Errr...
Re: Piston throw control
Ivey
This is common in industry, only with a different type of valve. There is a giamongous thread o nthis topic. I'm sure you can find it.
1139 Alumni
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
http://www.chiefdelphi.com/forums/sh...ght=pneumatics
This thread has much on the subject and yes it is possible with our parts. 263 has done it on 01 and 03.
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 10-02-2004, 19:48
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
And 1108 did it in 2003 with our arms. I lay out how to put the system together several times in that thread and there is much discussion on issues involved with it.
Unread 10-02-2004, 20:51
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
Its practically impossible to do. Its either all or nothing.
______________________________
I didn't break it!
Unread 10-02-2004, 21:08
AKA: Nelson Green
Read posted thread. It is possible. I've done it. It works well.
edit: Sorry, that might be harsh. By routing the exhaust of a double solenoid you can do more things like controlling the throw of the piston. By switching between atmosphere and a stop on a single solenoid you control the piston. I've put diagrams and pictures up in the other thread. Look there for the details.
Unread 10-02-2004, 22:05
I didn't break it!
the impossible - thats what engineers do every day, turn the impossible into something we end up taking for granted :^)
Unread 13-02-2004, 14:09
alexrobotics alexrobotics is offline
alexrobotics is an unknown quantity at this point
Our team is trying to do something similar with an arm and it must be fairly acute b/c we are trying to use the pneumatics to position the multiplier ball.
I have looked through the other thread and I was wondering if anyone has some great up close pictures that make a multi-position arm without a lot of programming.
Unread 13-02-2004, 14:17
AKA: Nelson Green
The minimal amount of programming is a on/off switch for the single solenoid and a extended/retracted switch for the double solenoid. You can do this manually for practice. Choose the direction you want extend/retract and then turn on the single to move and turn off to stop where you want. Slow movements down by using the needle valves on the cyclinder and closing them all the way and then slightly opening them.
Unread 13-02-2004, 22:39
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
If you want it to stop in the same place all the time just take a piece of pipe and cut it to the right length and then slide it onto the shaft
our web site
Unread 17-02-2004, 15:23
Mr. Ivey's Avatar
Mark Ivey
AKA: Mark
Or I could just buy the SMC "off the shelf" three stage solenoid...
ivey
Unread 17-02-2004, 15:53
pras870's Avatar
pras870 pras870 is offline
AKA: Mike
#0870 (Team Rice)
pras870 can only hope to improve
Send a message via AIM to pras870
Actually, if you follow the flow chart, you cannot use any off the shelf solenoids.
Electronics (yes) -> Is the part a motor, solenoid, pump, or other actuator? (yes) -> No, it may not be used.
'02 SBPLI Rookie of the Year
'03 UTC Johnson & Johnson Award Winners
'03 SBPLI Kleiner Perkins Caufield & Byers Entrepreneurship Award Winners
'03 SBPLI Regional Winners
'04 SBPLI Xerox Creativity Award Winners
Piston throw Alex N. Pneumatics 2 21-01-2004 21:19
What do you wish you knew about the new control system? Joe Ross Control System 2 09-01-2004 21:47
Some code in C that we may need if we are in trouble Andrew Rudolph Chit-Chat 16 07-10-2003 21:34
how do i control a piston with a joystick Ryan Foley Programming 2 27-05-2003 17:13
more control options smokescreen Technical Discussion 17 05-03-2002 15:41
