Re: Piston throw control
And 1108 did it in 2003 with our arms. I lay out how to put the system together several times in that thread and there is much discussion on issues involved with it.
Its practically impossible to do. Its either all or nothing.
______________________________ I didn't break it! |
edit: Sorry, that might be harsh. By routing the exhaust of a double solenoid you can do more things like controlling the throw of the piston. By switching between atmosphere and a stop on a single solenoid you control the piston. I've put diagrams and pictures up in the other thread. Look there for the details. Last edited by ngreen : 10-02-2004 at 21:13. |
Our team is trying to do something similar with an arm and it must be fairly acute b/c we are trying to use the pneumatics to position the multiplier ball.
I have looked through the other thread and I was wondering if anyone has some great up close pictures that make a multi-position arm without a lot of programming. |
The minimal amount of programming is a on/off switch for the single solenoid and a extended/retracted switch for the double solenoid. You can do this manually for practice. Choose the direction you want extend/retract and then turn on the single to move and turn off to stop where you want. Slow movements down by using the needle valves on the cyclinder and closing them all the way and then slightly opening them.
#7
If you want it to stop in the same place all the time just take a piece of pipe and cut it to the right length and then slide it onto the shaft
#8
Or I could just buy the SMC "off the shelf" three stage solenoid...
ivey |
#9
Actually, if you follow the flow chart, you cannot use any off the shelf solenoids.
Electronics (yes) -> Is the part a motor, solenoid, pump, or other actuator? (yes) -> No, it may not be used. |
| Piston throw | Alex N. | Pneumatics | 2 | 21-01-2004 21:19 |
| What do you wish you knew about the new control system? | Joe Ross | Control System | 2 | 09-01-2004 21:47 |
| Some code in C that we may need if we are in trouble | Andrew Rudolph | Chit-Chat | 16 | 07-10-2003 21:34 |
| how do i control a piston with a joystick | Ryan Foley | Programming | 2 | 27-05-2003 17:13 |
| more control options | smokescreen | Technical Discussion | 17 | 05-03-2002 15:41 |
