Go to Post The world isn't changed by people playing it safe. - Andrew Y. [more]
Unread 10-02-2004, 20:03
Greg's Avatar
Greg Greg is offline
FRC #1075 (Sinclair Sprockets)
Greg is on a distinguished road
Send a message via ICQ to Greg Send a message via MSN to Greg
Re: Help! My 2003 Bot compressor won't shut off
If you really have no idea what pins the pressure switch was connected to, and you dont have access to the source code from last year, all you have to do is remove the spike, and wire the compressor directly to the fuse through the pressure switch. While illegal at a competition, this will most definitely work. In fact, we showed up to a regional like this last year and had to change it to pass inspection (we didnt know this was illegal).
Unread 10-02-2004, 20:14
Do you understand why it is illegal or just that it is?
The Switch is rated for .5 amps (IIRC) while the pump can draw 10 amps. You may get away with it for a while, but it certainly isn't a good practice.
The Science Channel to broadcast FIRST documentary Andy Baker General Forum 49 01-03-2004 14:03
The Autodesk Design Awards 2003 – Call for Entries Brandon Martus 3D Animation and Competition 1 26-12-2003 18:40
Image Discuss: Rookie Team 1108 w/ 2003 Bot HYO CD47-Bot Robot Showcase 2 07-04-2003 23:37
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
pic: RAGE Bot 2003 in action CD47-Bot Extra Discussion 8 30-03-2003 00:29
