Drill Transmissions Wobbling???
Tonight we assembled one of our transmissions for the robot. Upon assembly we noticed that the transmissions were wobbling. We took the motors off the transmissions and ran them and they still have a wobble. We could not think of a cause for this problem as we have not done anything to the gearboxes to cause this problem. Has any other team experienced this problem this year or in the past? We would appreciate any help.
Thanks ![]() |
Re: Drill Transmissions Wobbling???
Whe have the same problem. I would like to know the answer tool.
I didn't break it! |
Just a thought. Try tighting the mounts. the hex cuplings arn't truning "true" so maybe it will work how knows.
________________________________ I didn't break it! |
If we tighten down the mounts it will cause the motor to bind, I wouldnt suggest trying it unless you want to replace your drill motors.
We had a similair problem last year. We blamed many things(the frame, the wheels, Dave, etc.). This year we fixed the problem with one simple equation. Drill motor=bad At some point I would like to know what really went wrong, but that's all I know for now. |
I took a close look at it and it seemd to be the hexagnel cuplink the connects to the drive shaft. It acts as if you would put a drill bit wrong into a drill. It wobbles the sameway. Thus It would seem that the position to the hole is slightly off.
#7
is that bad? how do you know how tight you should crank it |
#8
NO don't tighten the motors. It will cause the motors to bind. Then you'll have to buy a new motor for oh about....$70. Just look at my last post.
#9
The drill tranny is one of the "Great and Terrible" things of FIRST.
They are great because they have a lot of engineering all baked in for you. They are terrible because they can set a lot of traps if you don't know what you are doing (and even if you DO know what you are doing sometimes). I really don't like the current drill mounts for 2 reasons. #1 the output shafts cannot take a side load. #2 The drill motors are not really held very well. We used the drills & drill mounts last year. They were BY FAR our highest failure system on out robot. We are not using them this year. Joe J. |
#10
Just a thought. Good luck everyone! Matt |
#11
There is a solution to the problem. If you loosen the pillow blocks this will allow the akles to give a little so you dont ruin the motor. Just a thought.
#12
then possibly loosen the motor mounts or what ever your axels are mounted on.
#14
We torque all of our drivetrain bolts while the motors are running. This ensures the best alignment of things.
#15
I have tested the motors and gearboxes both on and off of our transmissions so it appears that it is either the shaft or the coupler supplied by first that is causing the problems, anyone have any solutions to that problem?
| Portable cordless drill press | Gui Cavalcanti | Technical Discussion | 25 | 03-08-2003 22:21 |
| drill motor mounts- again | Jeff Sharpe | Motors | 6 | 07-04-2003 23:20 |
| Emergency drill trade/sell | Anarkissed | General Forum | 3 | 16-02-2003 22:37 |
| A little tip about those drill transmissions and bearings | archiver | 2001 | 6 | 24-06-2002 00:22 |
| drill motor transmissions | nwagers | Motors | 16 | 29-01-2002 10:54 |
