Go to Post These awards aren't easy to get, and if a team deserves an award, they deserve to be cheered on for it. - tckma [more]
  #46   Spotlight this post!
Unread 10-02-2004, 21:38
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: Desensitizing Joysticks
Wouldn't a hyperbola work? not the regular kind; try Y=sqrt(R^2+X^2)-R. basically, close to zero, it's a curve, but farther away, it's close to linear. Excel that and try it. But it won't reach maximum value ever. A coefficient would be necesary. R is the value at zero.
  #47   Spotlight this post!
Unread 10-02-2004, 21:39
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
Take out the set screw in the joystick. It should spin like the wheel on the robobt.
I didn't break it!
  #48   Spotlight this post!
Unread 10-02-2004, 23:01
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
plenty of mathematical forms work, just pick one.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
  #49   Spotlight this post!
Unread 16-11-2004, 16:26
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Thumbs up Re: Desensitizing Joysticks
Originally Posted by Scooter
What we use is a exponenetial function. This simply shifts the power curve out some while still retaining full power at the edges. Instead of it being completely linear, it follows a curve (that looks suspiciously like a cubic function). At 50% joystick travel, you may only have 33% motor output, but at 100% joystick travel, you have 100% motor output.
Another technique that I learned from flying R/C Heli's is to grip the joystick at the bottom with just a few fingers....This helps to make movements less extreme....they only downside is that it is a little tuffer to get to the buttons...The advantage is that the movement comes from the fingers instead of the arm and wrists, and it affords you alot more accuracy.
Bill
I am new to Chief Delphi forum but recommend that you add one more
bit of functionality - a rate limiting function. The exponential curve via
table lookup solves one problem but not the problem of quick changes
in torque. If you use both methods simultaneously, it can help to
solve range/resolution issues associated with Joystick input to pwm0x output,
and torque/speed transitions from positive/negative to negative/positive.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
  #50   Spotlight this post!
Unread 16-11-2004, 18:57
Gusman1188 Gusman1188 is offline
FRC #0870
Rookie Year: 1930
Gusman1188 will become famous soon enoughGusman1188 will become famous soon enough
Originally Posted by KenWittlief
I dont understand how putting a deadband around 127 will make the joystick less sensitive
in fact, your bot is going to lurch when the joystick is moved just outside the deadband
dividing the joystick variable by two, and then correcting the zero point by adding 64 - makes the full forward or full right... positions of the joystick equal to half forward, or half right... making the entire motion of the joystick less sensitive
and making it easier to make fine control adjustments to the motion of the machine while driving - ie when you want to manuver to capture a ball, or position the robot precisely on the field.
Looking back on this post, the reason we did this was because our joysticks didn't stay exactly centered and you would have to re-adjust the trim 85 billion times in a match if we used those joysticks.
Team R.I.C.E. 870
2006 SBPLI Regional Winner
2006 SBPLI Imagery Award
2005 SBPLI Regional Winner
2004 SBPLI Xerox Creativity
2003 SBPLI Regional Winner
2003 CT J&J Sportsmanship
2003 SBPLI KPC&B Entrepenuership
2002 SBPLI Rookie All-Star
  #51   Spotlight this post!
Unread 16-11-2004, 19:12
M. Hicken's Avatar
M. Hicken M. Hicken is offline
Where am I?
AKA: I AM PACO
#0219 (Team Impact)
Team Role: Driver
M. Hicken is a jewel in the roughM. Hicken is a jewel in the roughM. Hicken is a jewel in the rough
Send a message via AIM to M. Hicken
im not a fluent programmer. im learning java in class. but our programmer wrote in a zeroing button on the control board after the joysicks being a pain and never going back to zero. big mistake, the joysticks hold a value, i forget what it is, and after a while the values become off due to the mechanics of the stick. The zero button made the robot very hard to drive,if you zero it while its not PERFECT, the handling falls apart.
just sharing an experience
If duct tape isnt the answer you're looking for, you're asking the wrong question
There is no such thing as a stupid question, there are just a lot of inquisitive idiots
Personal rookie year: 2002
Team Impact 219: 1998
  #52   Spotlight this post!
Unread 16-11-2004, 19:28
AKA: Jamie Bliss
In programmer terms? Do you mean a loop to change the speed only so fast?
  #53   Spotlight this post!
Unread 16-11-2004, 21:15
scitobor 617's Avatar
scitobor 617 scitobor 617 is offline
More nerd than you can handle!
AKA: Alan Meekins
FRC #0617 (HSHS 617 "DUKE")
scitobor 617 will become famous soon enoughscitobor 617 will become famous soon enough
Send a message via AIM to scitobor 617
My team had a similr problem. To correct it I wrote some code that would center the joysticks when a button was pressed. It would consider the current position of the joystick the center. It worked by finding the difference between true center and that position and always adding it to the output for the motors. It worked well on our robot and should not be to hard to edit for your robot.
P.S. If you would like the code PM me. The program was a little rushed so it was a tad buggy, nothing too major, but I'm sure with a little work they can be worked out.
Beta testers needed!
http://www.nullagent.no-ip.com
Your kidding, there are other operating systems besides Linux?!
  #54   Spotlight this post!
Unread 17-11-2004, 14:31
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Originally Posted by bob1million
My fellow programmers and I have tried many different ways to desensitize our joysticks, but none of ways work very well. Does anyone know a good way to desensitize them?
It seems the problem is big enough to cause some serious thread resurrection.
Here was Team 188's solution to sensitive joysticks for 2004 courtesy Carol, Honson, Tristan and myself:
temp_p1_long = (signed long)p1_y - 128;
pwm01 = (unsigned char)(((temp_p1_long * temp_p1_long * temp_p1_long)  >> 14) + 128);
temp_p2_long = (signed long)p2_y - 128;
pwm02 = (unsigned char)(((temp_p2_long * temp_p2_long * temp_p2_long)  >> 14) + 128);
make sure you declare temp_p1_long and temp_p2_long as signed long beforehand.
In a nutshell, it's a cubic transfer function that makes the robot accelerate exponentially when you push the joystick. There's a nice wide area to operate slowly, yet full speed is still there when you push it all the way.
We spent a few days testing different transfer functions, and this one worked out the best.
It's pretty CPU intensive (multiplying long integers), and a look-up table would be faster, but try it for a quick and dirty way to get things working smoothly. You can generate a look-up based on the code later on.
Cheers!
-SlimBoJones...
  #55   Spotlight this post!
Unread 24-11-2004, 18:21
tribotec_ca88's Avatar
tribotec_ca88 tribotec_ca88 is offline
FIRST-a-holic
AKA: Camila Fitzgibbon
FRC #1382 (Tribotec Team)
Team Role: Student
tribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nicetribotec_ca88 is just really nice
Send a message via ICQ to tribotec_ca88 Send a message via MSN to tribotec_ca88 Send a message via Yahoo to tribotec_ca88
Exclamation Re: Desensitizing Joysticks
Absolutely...our team also realized the joysticks provided by FIRST proportionalize poor handling...Don't know if you'd had a look at the white papers on this website yet but team 1382's written one about the advantages of converting the linear curve of the joystick into an exponential one (and includes source code). I guarantee it'll give you some ideas...
Link:
http://www.chiefdelphi.com/forums/pa...le&paperid=280
1382 Tribotec Team - Brazil
2005 NJ Regional GM Industrial Design Award
2005 NJ Regional Website Excellence Award
2004 NJ Regional Semifinalists
Programming joysticks NoRemorse Programming 29 24-02-2004 20:26
number of joysticks doy Rules/Strategy 5 01-02-2004 00:05
Team 524 has Team 362's spare joysticks from last year. archiver 2001 0 24-06-2002 02:36
Could use some help with joysticks . . . archiver 2001 5 23-06-2002 23:36
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
