Re: Mounting the arm
Who needs arms when you've got a..... forklift! Our monster drawer sliders are mounted with two reinforced, shelf, L-brackets that are bolted to the frame and the lift.
Now that i think about it, Our robot may have an additional function as an organizer ![]() |
and the survey says..................
bubblegum that's right, we've locked the entire team in the basement for the past 4 weeks so that they can dilligently chew up enough bubblegum to not only attach the arm but to make on the spot repairs at the competitions. |
Mount it 3 ways!
A) Very carefully and acurately - so you don't extend the profile. B) Very securely - so when you extend it somehow, your robot doesn't break. C) Very center of gravity-ish - so you don't tip as you retract and/or pivot it!! That's all I got! |
| team 314 sweeper arm | angier314 | Chit-Chat | 0 | 26-03-2003 15:32 |
| Reflected Inertia? | archiver | 2001 | 9 | 24-06-2002 03:50 |
| anyone use an arm to help balance | archiver | 2001 | 8 | 24-06-2002 02:46 |
| Controlling Arm travel - Limit Switch or Mechanical Stop? | archiver | 2001 | 8 | 23-06-2002 23:55 |
| telescoping arm & ten second rule | Ben Mitchell | Rules/Strategy | 4 | 18-02-2002 21:37 |
