Go to Post STICK WITH WHAT WORKS FOR YOU!!! - Will Hanashiro [more]
Unread 11-02-2004, 09:50
swabbie58 swabbie58 is offline
swabbie58 is an unknown quantity at this point
Flow rate / remaining pressure
Assume a 6.6CF tank that receives an additional 59.4CF of air every one-second cycle. Within eight cycles the pressure would reach 1022psi and within sixteen cycles 2033psi. The tank is equipped with a safety valve set for 3,000psi. If I begin releasing air after the 16th cycle, how can I calculate the flow rate given that 1) I don't want the pressure to go above that 3,000psi threshold and 2) the tank is constantly being refreshed at that rate of 59.4CF/sec.?
Unread 11-02-2004, 09:56
Re: Flow rate / remaining pressure
If you don't want to keep increasing the tank pressure indefinitely, the outgoing flow rate obviously has to be the same as or greater than the incoming flow rate.
Unread 11-02-2004, 11:42
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Do you want a constantly increasing outgoing flow rate to equalize with maximum pressure or a constant one that in a certain number of cycles won't let the pressure breach 3,000 psi?
Unread 11-02-2004, 12:06
Constant output flow rate is what is needed. As this looks to allow the pressure in the tank to keep increasing, it may also work to add more exhaust hoses for additional output.
Unread 11-02-2004, 12:08
True, I am just having trouble comparing apples to oranges. For example, the 59.4CF of air coming in starts life at 14psi and is forced into the 6.6CF tank. The force pushing it along will be sufficient to do this job. The air in the tank is constantly increasing in pressure under this influx or decreasing as some is exhausted. I need a formula to figure out how this tank pressure will be simultaneously influenced by both of these processes.
Unread 11-02-2004, 12:57
Zotas Zotas is offline
FRC #0177 (Bobcat Robotics)
Rookie Year: 1995
Zotas will become famous soon enough
I think you are reading more into your problem more than you need to. You could easily install a pressure switch to turn off your compressor at a specified setpoint.
At any rate, you want the mass flow at the inlet and exit to be the same. Mass flow is a function of density, velocity and the area at the inlet / exit.
Continuity equation:
rho1V1A1 = rho2V2A2
rho1 = density at inlet
V1 = velocity at inlet
A1 = area at inlet
rho2 = pressure at exit
V2 = velocity at exit
A2 = area at exit
Also, you probably want the ideal gas law to convert for density:
PV = NRT
P = pressure
V = volume
N = moles
R = gas constant - 8.314 (kpa*m^3)/(kmol*K)
T = temperature
There are a few websites that can explain the theory. Try www.engineeringtoolbox.com. If I were you I would worry more about the mechanical energy needed to maintain your assumed constant flow at high pressure.
-Jake
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Pneumatic equations Ghetto_Child Pneumatics 2 13-01-2002 16:42
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
