Go to Post "Heres a band aid to keep your blood off the robot." - littleelectron [more]
Unread 11-02-2004, 12:08
swabbie58 swabbie58 is offline
swabbie58 is an unknown quantity at this point
Re: Flow rate / remaining pressure
Originally Posted by Alan Anderson
If you don't want to keep increasing the tank pressure indefinitely, the outgoing flow rate obviously has to be the same as or greater than the incoming flow rate.
True, I am just having trouble comparing apples to oranges. For example, the 59.4CF of air coming in starts life at 14psi and is forced into the 6.6CF tank. The force pushing it along will be sufficient to do this job. The air in the tank is constantly increasing in pressure under this influx or decreasing as some is exhausted. I need a formula to figure out how this tank pressure will be simultaneously influenced by both of these processes.
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Pneumatic equations Ghetto_Child Pneumatics 2 13-01-2002 16:42
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
