Go to Post Skill in software engineering is all about algorithmic understanding and intuition. Implemenation is an important, but ultimately secondary, concern. Programming languages are more or less arbitrary. - phrontist [more]
Unread 11-02-2004, 13:31
emusteve's Avatar
emusteve emusteve is offline
AKA: Steve Martin
#0470 (Alpha Omega)
emusteve is just really niceemusteve is just really niceemusteve is just really niceemusteve is just really nice
Problems reading io pins as a group
I'm trying to read a group of 4 io pins to get a numerical value as the status of an outboard device. I'm trying it out using the edubot controller so I'm looking at io pins 1-4 which translates to PortA bits 0-3. I was trying to do the following:
sensor_value = (PORTA & 0x0f);
iIt compiles ok, but the result is always 0. I double-checked that I have set the pins to INPUT, and have set the number of analog channels to NO_ANALOG. sensor_value is an unsigned char.
I also tried reading the pins individually as rc_dit_in01 through rc_dig_in04 and got the proper values, so I know the hardware is ok. Anyone know what gives here? Any help would be appreciated.
On another note, I often have problems getting the edubot to take to a program upload. Sometimes it takes 2 or 3 tries before it will run. And it won't hold through a power-down. Do I just have a bad machine? this is true for a fresh load of the Default Code as well as my own, and the same behavior with both versions of the IFI Loader.
Unread 11-02-2004, 13:57
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
Re: Problems reading io pins as a group
worse case scenario, you could always just do this:
portAvalue = (rc_dig_in01 << 3) & (rc_dig_in02 << 2) & (rc_dig_in03 << 1) & rc_dig_in04;
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Unread 11-02-2004, 14:35
We're doing the same thing with a BCD switch.
I tested this on the EDU controller and it worked.
With unconnected pins you get 0x0F
With dig I/O 1 signal-to-gnd you get 0x0E
With dig I/O 1&2 connected you get 0x0C
in user_routines.c, User_Initialization()
Set_Number_of_Analog_Channels(NO_ANALOG);	 /* See ifi_aliases.h */
IO1 = IO2 = INPUT;
IO3 = IO4 = IO5 = INPUT;
IO6 = IO8 = IO10 = INPUT;
// IO3 = IO4 = OUTPUT;
// IO5 = IO7 = IO9 = OUTPUT;
IO7 = IO9 = OUTPUT;
IO11 = IO13 = IO15 = OUTPUT;
// rc_dig_out03 = rc_dig_out04 = 0;
// rc_dig_out05 = 0;
in user_routines.c, Process_Data_From_Master_uP()
	PrintString((char *) "PORTA = ");
	PrintByte(PORTA & 0x0f);
Unread 11-02-2004, 14:38
The Lucas's Avatar
CaMOElot, it is a silly place
Shouldn't it be
portAvalue = (rc_dig_in01 << 3) + (rc_dig_in02 << 2) + (rc_dig_in03 << 1) + rc_dig_in04;
[EDIT]
actually it should be
portAvalue = (rc_dig_in04 << 3) + (rc_dig_in03 << 2) + (rc_dig_in02 << 1) + rc_dig_in01;
since rc_dig_in01 is in bit0 (least significant) of PORTA
[/EDIT]
Robot Inspector
Unread 11-02-2004, 17:00
Computer Guy
AKA: Dav
whichever - it depends on what direction you hooked the device up in
Unread 11-02-2004, 17:40
emusteve's Avatar
AKA: Steve Martin
#0470 (Alpha Omega)
The point was to make the routine as fast as possible by not taking the time and space to read each line individually. I've already got that to work, but it makes for messy code.
Mark's post has the greatest similarity to mine in code structure. I wonder why PrintByte worked for him, but using PORTA to transfer a value to another variable doesn't seem to?
Steve
Unread 11-02-2004, 18:33
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
All around, False means closed (On) True means open (off).
You can add, or just OR it (| I think), Which makes more sense to me. You're merging bits, not adding values.
Unread 11-02-2004, 21:21
Computer Guy
AKA: Dav
the way it works out, either will work. you're right though, bitwise OR is probably faster.
Unread 11-02-2004, 22:00
Umm Errr...
The problem is that you are using bitwise and(&), you should be using logical AND(&&).
the difference is this:
"&" (bitwise and) ANDs each corresponding bit individually.
11110000 & 11111111 = 11110000
10101010 & 10101010 = 10101010
"&&" (logical and) ANDs the entire word at a time. (it will only be true if the two arguements are the same.)
11110000 && 11111111 = 00000000
10101010 && 10101010 = 11111111
1139 Alumni
Unread 11-02-2004, 22:14
Computer Guy
AKA: Dav
I don't believe that's what he's trying to do - he's using the & to mask off the four bits he's trying to read, which is correct.
Unread 11-02-2004, 22:37
Umm Errr...
Originally Posted by The Lucas
Shouldn't it be
[EDIT]
[/EDIT]
Technically bit0 would be the MSB, because of the endianness.
Btw jsut wxactly what are you trying to do? mask off bits or compare values?
1139 Alumni
Unread 12-02-2004, 10:09
Steve
I originally ran:
unsigned char port_a;
port_a = PORTA & 0x0f;  /* mask off unused bits */
PrintByte(port_a);
to more closely emulate what you were doing. I simplified it to the minimum number of lines before posting.
This works as well, so it isn't an assignment problem.
Unread 12-02-2004, 11:35
steven114 steven114 is offline
Programming Wizard and Team Captain
AKA: Steven Schlansker
FRC #0114 (Eaglestrike)
steven114 is a jewel in the roughsteven114 is a jewel in the roughsteven114 is a jewel in the rough
Send a message via AIM to steven114
I believe that is wrong - && returns 1 if both arguments are true (non-zero). This is because the logical and works on two boolean values, and returns a third. Anything except 0 is treated as true in C.
Unread 12-02-2004, 12:22
Computer Guy
AKA: Dav
steven is correct - anything with a set bit qualifies as the "true" state, the only false state being 0.
you cannot really show how the boolean && works using bits - it's a logical operator, versus the bitwise operator &.
Unread 13-02-2004, 00:30
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Ahh.. I found the problem..
Mark, if you notice, tested his code on the EDU controller, where PORTA0-3, is bits 1-4
However on the fullsize RC, bits1-4 are PORTB2-5. Infact PORTA isn't even used on the outputs at all.
The full size RC uses parts of Ports B,H,& J
The EDU controller uses parts of Ports A,F,H.
And they actually use different halves of Port H, so I really would suggest against using the port names directly.
Hope this helps....
TTL pins Dave... Control System 3 07-02-2004 23:59
Joystick problems archiver 2001 3 24-06-2002 02:40
Hits, Misses, & Suggestions -- long message archiver 2000 17 23-06-2002 23:36
Nationals a la NCAA archiver 2000 20 23-06-2002 22:25
