Go to Post And your other point, "why a debate over a nonexistent rule?". Its summer, we're not building robots, and we're geeks. What else are we supposed to do? - EHaskins [more]
Unread 11-02-2004, 15:17
Tridelvior Tridelvior is offline
Windbringer
#0348
Tridelvior is an unknown quantity at this point
Non Overlay and absolute? Help.
I keep getting this message when I try to build the project
Error - section '_entry_scn' type is non-overlay and absolute but occurs in more than one input file.
Errors : 1
BUILD FAILED: Wed Feb 11 14:01:32 2004
Team 348 Programmer/Animator/Slacker
Minion #341
Unread 11-02-2004, 15:57
Re: Non Overlay and absolute? Help.
That's an interesting one.
That's declared in ifi_startup.c and is the RESET_VECTOR
The error occurs if:
#pragma code _entry_scn=RESET_VECTOR
occurs more than once.
Did you by any chance #include "ifi_startup.c" anywhere?
Unread 11-02-2004, 16:41
Windbringer
#0348
Exclamation Re: Non Overlay and absolute? Help.
Hmm..thats interesting.
Now I've got the same error but different place.
Error - section 'InterruptVectorLow' type is non-overlay and absolute but occurs in more than one input file.
Its now within the user_routines_fast.c (Thats the only place where "#pragma code InterruptVectorLow" is.)
#pragma code InterruptVectorLow = LOW_INT_VECTOR
void InterruptVectorLow (void)
_asm
goto InterruptHandlerLow /*jump to interrupt routine*/
_endasm
This probably has an obvious answer..but what does it mean?
Minion #341
Unread 11-02-2004, 16:56
Don't #include any of your .c files.
Now you have #include "user_routines_fast.c" somewhere...
The real answer is to #include .h files only.
.h files usually only reference things that will be defined elsewhere and the names won't conflict if they are mentioned in more than one file. It just lets the different files know they are talking about the same "thing."
.c files on the other hand actually create "things" and if you try creating the same thing twice (by including the .c file) the compiler won't know which of two routine "x"'s you really wanted it to execute.
Unread 11-02-2004, 17:23
Windbringer
#0348
Thanks that helped but now I'm getting:
C:\ARGH\user_routines.c:189:Warning [2058] call of function without prototype
C:\ARGH\user_routines.c:191:Error [1203] too few arguments in function call
and the error seems to be within the user_routines.c
pGenerate_Pwmsrintf("Port1 Y %3d, X %3d, Fire %d, Top %d\n",(int)p1_y,(int)p1_x,(int)p1_sw_trig,(int)p1_ sw_top); /* printf EXAMPLE */
Generate_Pwms(pwm13,pwm14,pwm15,pwm16);
aww jeez
Minion #341
Unread 11-02-2004, 17:47
Windbringer
#0348
Talking Re: Non Overlay and absolute? Help.
After a fun round of re-downloading the default code i have finally gotten it to work. Thank you very much for your help. I know who to contact if I have any more difficulties.
Minion #341
Unread 12-02-2004, 09:52
It's always more fun to debug someone else's code.
It's always your own code that drives you nuts!
Good Luck!
