Go to Post To quote Harrison Ford: "Never tell me the odds". - [more]
Unread 11-02-2004, 15:49
Re: If any of you have the time an answer please?
epoxy? (JB Weld)
hose clamps?
Unread 11-02-2004, 16:02
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: techniques to fasten PVC Pipe to a metal rod?
There are lots of way to do this. Some good easy way said above. It would help if we knew what you wanted this to do. Bolting it would make it easier to replace but you could sheer the bolt off and you wouldn't be attached anymore....mechanism might not work anymore for that match. Epoxy would keep it from becoming unattached but more difficult to replace. I would reccommend bolting to start, test it, and if you need an epoxy or more permanent solution you can do it then.
Robot/Goal scoring: Official Answer Mike Martus Mike Martus OCCRA 6 21-10-2003 23:51
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
How long should production time be??? archiver 1999 4 23-06-2002 23:16
need help with time zone! Ken Leung General Forum 6 25-06-2001 12:44
