Go to Post In an education culture that hinges on having the perfect grades and perfect SAT scores to get into the perfect colleges, I enjoy providing an environment where students are encouraged to test their own hypothesis, challenge their assumptions, and regularly fail. - Michael Corsetto [more]
Unread 11-02-2004, 18:45
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
Re: If any of you have the time an answer please?
Could you clarify how you wanted to connect the two pipes? Do you want to butt them end to end or put one at a perpendicular angle to the other?
If you just wanted to butt the two ends together you could make some kind of sleeve or coupling then just use screws or bolts to hold the pipes into the sleeve.
Unread 11-02-2004, 18:54
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Two ways.
1. Weld a perpendicular piece of mettal on your metal rod that fits into pvc and then bolt through pvc.
2. Get dowel of wood to fit for a short distance inside pvc, 3 to 4 inches. Cut hole barely too small for metal rod. Cut slot from bottom of pvc and wood up to that hole. Slide rod in. Clamp down wood on pipe using bolts.
Still don't know what you're looking for but oh well.
Unread 11-02-2004, 19:12
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Re: techniques to fasten PVC Pipe to a metal rod?
HMMMMM thats a tough one... what was that stuff?/ four letter word ??, starts with a "g" hmmmmm, ummm how bout GLUE
That still is a tough one to figure out. There are quite a few differnt glues they cold use also you would have to add in that both materials are non porus.
Unread 11-02-2004, 19:36
occra 23.
AKA: ryo
None #1481
yeah. don't use stick glue. i think it won't work.
it matters on the size of the rod, but if it's a big diameter, you might be able to use wire. maybe. its easy to suspend stuff in mid-air.. kinda.
well you said you were open to ANY ideas so...
Unread 12-02-2004, 07:53
If you are simply slipping the PVC over the end of a rod...
Cut a slit in the PVC (down the length of the overlap with the rod.) , slide it over the end of the rod, secure with a hose clamp or two that sqeezes the PVC against the rod.
Unread 12-02-2004, 23:02
roknjohn roknjohn is offline
roknjohn is an unknown quantity at this point
Drill a hole in a PVC end "CAP", and stick a bolt thru from the inside. Tighten a nut down on it from the other side (really good). Then, glue the cap on the pipe with PVC cement.
For shrimp baiting, we use 12 foot 1.5" pvc pipes to mark the underwater bait. One year we added a 15" threaded rod to the end to help plant in firm bottoms.
Unread 12-02-2004, 23:07
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Hose clamp
strap it on and screw it down
Unread 19-02-2004, 12:14
pryoplasm's Avatar
pryoplasm pryoplasm is offline
Pit Crew/Electrical
AKA: Russ
#0069
pryoplasm can only hope to improve
Originally Posted by Tytus Gerrish
Hose clamp
seconds the hose clamp. they work well, and arent heavy.
Cut these eyes, but I will see,
Kiss these lying lips for me,
Stroke this skin, and I will kneel,
Brutalize me, I will heal...
-KMFDM
Robot/Goal scoring: Official Answer Mike Martus Mike Martus OCCRA 6 21-10-2003 23:51
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
How long should production time be??? archiver 1999 4 23-06-2002 23:16
need help with time zone! Ken Leung General Forum 6 25-06-2001 12:44
