Go to Post You all are brilliant people. - Andy Baker [more]
Unread 11-02-2004, 15:38
1166's Avatar
1166 1166 is offline
AKA: Vex
#1166 (The Highlanders)
Team Role: Animator
1166 can only hope to improve
Send a message via AIM to 1166
If any of you have the time an answer please?
Does anybody know of any techniques that we can use to fasten PVC Pipe to a metal rod somehow? We're open to any ideas, thanks.
-Vex
Unread 11-02-2004, 15:48
ShadowKnight's Avatar
ShadowKnight ShadowKnight is offline
FRC #1719 (Umbrella Corporation)
ShadowKnight has a spectacular aura aboutShadowKnight has a spectacular aura about
Re: If any of you have the time an answer please?
how do you want it affixed? because it's possible that you could just drill a BIG hole the size of the metal rod through the pvc and drill a through bolt through the side to secure it. Another idea is that you could bevel out the edges enough along the curve of the pipe to through bolt it...
Gracious Professionalism isn't simply courtesy or tradition, it's a way of life
I met her through FIRST...
We only are where we are by God's providence and by no other...
Unread 11-02-2004, 15:49
epoxy? (JB Weld)
hose clamps?
Unread 11-02-2004, 16:02
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Re: techniques to fasten PVC Pipe to a metal rod?
There are lots of way to do this. Some good easy way said above. It would help if we knew what you wanted this to do. Bolting it would make it easier to replace but you could sheer the bolt off and you wouldn't be attached anymore....mechanism might not work anymore for that match. Epoxy would keep it from becoming unattached but more difficult to replace. I would reccommend bolting to start, test it, and if you need an epoxy or more permanent solution you can do it then.
Unread 11-02-2004, 18:39
Stillen Stillen is offline
Stillen is just really niceStillen is just really niceStillen is just really niceStillen is just really niceStillen is just really nice
Send a message via ICQ to Stillen
-Vex
HMMMMM thats a tough one... what was that stuff?/ four letter word ??, starts with a "g" hmmmmm, ummm how bout GLUE
Unread 11-02-2004, 18:45
KyleGilbert45's Avatar
KyleGilbert45 KyleGilbert45 is offline
KyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant futureKyleGilbert45 has a brilliant future
Could you clarify how you wanted to connect the two pipes? Do you want to butt them end to end or put one at a perpendicular angle to the other?
If you just wanted to butt the two ends together you could make some kind of sleeve or coupling then just use screws or bolts to hold the pipes into the sleeve.
Unread 11-02-2004, 18:54
AKA: Nelson Green
Two ways.
1. Weld a perpendicular piece of mettal on your metal rod that fits into pvc and then bolt through pvc.
2. Get dowel of wood to fit for a short distance inside pvc, 3 to 4 inches. Cut hole barely too small for metal rod. Cut slot from bottom of pvc and wood up to that hole. Slide rod in. Clamp down wood on pipe using bolts.
Still don't know what you're looking for but oh well.
Unread 11-02-2004, 19:12
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
That still is a tough one to figure out. There are quite a few differnt glues they cold use also you would have to add in that both materials are non porus.
Unread 11-02-2004, 19:36
occra 23.
AKA: ryo
None #1481
yeah. don't use stick glue. i think it won't work.
it matters on the size of the rod, but if it's a big diameter, you might be able to use wire. maybe. its easy to suspend stuff in mid-air.. kinda.
well you said you were open to ANY ideas so...
Unread 12-02-2004, 07:53
If you are simply slipping the PVC over the end of a rod...
Cut a slit in the PVC (down the length of the overlap with the rod.) , slide it over the end of the rod, secure with a hose clamp or two that sqeezes the PVC against the rod.
Unread 12-02-2004, 23:02
roknjohn roknjohn is offline
roknjohn is an unknown quantity at this point
Drill a hole in a PVC end "CAP", and stick a bolt thru from the inside. Tighten a nut down on it from the other side (really good). Then, glue the cap on the pipe with PVC cement.
For shrimp baiting, we use 12 foot 1.5" pvc pipes to mark the underwater bait. One year we added a 15" threaded rod to the end to help plant in firm bottoms.
Unread 12-02-2004, 23:07
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Hose clamp
strap it on and screw it down
Unread 19-02-2004, 12:14
pryoplasm's Avatar
pryoplasm pryoplasm is offline
Pit Crew/Electrical
AKA: Russ
#0069
pryoplasm can only hope to improve
Originally Posted by Tytus Gerrish
Hose clamp
seconds the hose clamp. they work well, and arent heavy.
Cut these eyes, but I will see,
Kiss these lying lips for me,
Stroke this skin, and I will kneel,
Brutalize me, I will heal...
-KMFDM
Unread 19-02-2004, 12:16
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
One way is to get 1/4" or 34" bolts and bolt the pipes. Make sure its really tight though. You could bolt them in a "X" pattern.
___________________________
If all else fails, use a bigger hammer.
Unread 19-02-2004, 12:21
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
You can buy PVC adapters to get you to a pipe thread. ID and OD.
Then you can use a threaded rod ro connect with a solid connection.
Use PVC cement to put the plastic together.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Robot/Goal scoring: Official Answer Mike Martus Mike Martus OCCRA 6 21-10-2003 23:51
Solution to Timing Loops Steven Carmain Programming 39 10-02-2003 13:33
Robot motion after the time has run out. Randy Ai Rules/Strategy 1 06-01-2003 17:17
How long should production time be??? archiver 1999 4 23-06-2002 23:16
need help with time zone! Ken Leung General Forum 6 25-06-2001 12:44
