Re: techniques to fasten PVC Pipe to a metal rod?
it matters on the size of the rod, but if it's a big diameter, you might be able to use wire. maybe. its easy to suspend stuff in mid-air.. kinda. well you said you were open to ANY ideas so... |
If you are simply slipping the PVC over the end of a rod...
Cut a slit in the PVC (down the length of the overlap with the rod.) , slide it over the end of the rod, secure with a hose clamp or two that sqeezes the PVC against the rod. |
Drill a hole in a PVC end "CAP", and stick a bolt thru from the inside. Tighten a nut down on it from the other side (really good). Then, glue the cap on the pipe with PVC cement.
For shrimp baiting, we use 12 foot 1.5" pvc pipes to mark the underwater bait. One year we added a 15" threaded rod to the end to help plant in firm bottoms. |
Hose clamp
strap it on and screw it down |
seconds the hose clamp. they work well, and arent heavy. |
| Robot/Goal scoring: Official Answer Mike Martus | Mike Martus | OCCRA | 6 | 21-10-2003 23:51 |
| Solution to Timing Loops | Steven Carmain | Programming | 39 | 10-02-2003 13:33 |
| Robot motion after the time has run out. | Randy Ai | Rules/Strategy | 1 | 06-01-2003 17:17 |
| How long should production time be??? | archiver | 1999 | 4 | 23-06-2002 23:16 |
| need help with time zone! | Ken Leung | General Forum | 6 | 25-06-2001 12:44 |
