Go to Post Awesome doesn't even scratch the surface here folks. - DonRotolo [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 11-02-2004, 21:33
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
pvc
I know this might seem obvious to some, but is pvc an allowed material? As in tubes? I couldn't find any info on it.
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 11-02-2004, 21:35
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Re: pvc
Sure it is, more than 50 percent of the teams use PVC every year- it's so light, adaptable, and durable..
Beacon and 10 Point ball PVC frame dimensions MrB General Forum 2 28-01-2004 08:35
PVC Wobbly in goal? Eric Reed General Forum 8 15-01-2004 10:25
45 degree PVC angle fittings: which? archiver 2001 2 23-06-2002 22:53
Goal...PVC is loose... archiver 2001 7 23-06-2002 22:38
pvc piping gthakore Rules/Strategy 3 09-01-2002 21:27
