Go to Post You don't always get what you pay for, but you hardly ever get what you don't pay for. - MrForbes [more]
Unread 11-02-2004, 15:46
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Battery Charging Box
<R19> The 12v Battery may only be charged by a 6 Ampere rated battery charger between matches. When
recharging Kit batteries, you may use the charger provided by FIRST or one with equivalent charging
current.
Should I interperet this to mean we can use any type of charger we wish as long as each battery is charged at a rate of 6 amps or less?
Unread 11-02-2004, 16:05
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Battery Charging Box
Sure, any 12V, 6A or less charger will work. I remember seeing one team with a device that charged 3 batteries at once. If you build a box to charge it in, I would recommend charging the battery upright rather than on its side (I think this gives a better charge because more of the lead is in contact with the acid). If your box is going to enclose the battery and charge, you might want to ventilate it. Good Luck
Robot Inspector
Unread 11-02-2004, 16:09
Carpe diem
Well the question was asked in hope we could use say a 10 Amp charger. Using electronics to limit charging to 6 Amps or less to each battery.
Unread 11-02-2004, 16:15
The Lucas's Avatar
Do you want to charge two batteries in parallel? If so I think it would be legal as long as you limited each output to 5 or 6 amps.
Robot Inspector
Unread 11-02-2004, 16:19
Carpe diem
Yes, parallel for the most part. With the appropraite circutry to isolate each battery and provide resistance if only one battery is connected.
Unread 11-02-2004, 21:22
hooking two batteries in parallel is very dangeous. There would be nothing to limit the current from one to the other, and a charged battery could easily source a hundred amps into a dead one. When electronics fail they often fail as a short circuit - so your current limiting circuit could become an inferno.
you are really better off using one charger per battery, because the charger senses the voltage across its terminals, and will limit itself to the battery with the higher charge
besides, if you have two or three 6 amp charges, and one fails, you are not dead in the water - if your custom muliti bat charger fails, or if FIRST says 'Hey you cant us that' you will be in deep weeds.
in fact, the more I think of it, Im pretty sure FIRST would not allow any custom battery chargers in the pit area - if it fails the battery could explode - imagine the resulting lawsuit when 20 or 30 people are sprayed with hot sulfuric acid and molten lead!
BTW - I assume you are not talking about charging the little backup battery this way too - you put 6 amps into that and you wont get out one chorus of 'pop goes the weasle' before it blows.
Unread 11-02-2004, 21:42
Carpe diem
People had been creating battery charging devices long before FIRST made the ruling last year prohobiting them last year. Many teams have them, and I have yet to see a fire or explosion. Anyone want to share some schematics?
I planned on hooking the 7.2V battery in parallel with the 12V Exide to keep it highly charged
Unread 12-02-2004, 08:06
DON'T DO THIS! If you do it, please be far away from me in the pits. I hate the smell of burning electrolyte and have never very much cared for shrapnel. As a few informed people have said on these fori in the past, FIRST means just what the rules state. Charge a single battery with a single charger at no more than 6 amps or the battery will be damaged and people might get hurt. Think about the consequences of connecting the 7.2 volt battery in parallel with the 12 volt battery. Even if the 7.2 volt battery was charged the potential difference is 12-7.2=4.8 volts. This voltage will drop across the internal resistance of each of the batteries and assuming that the NiCad resistance is very small then 4.8v/.011 ohms=436 amps Is that enough to scare you? If the gods are smilling on you, the NiCad will short and the wires feeding it will go incandescent for a few seconds before they burn open, showering the pit with burning copper and vinyl insulation.
As Ken has stated above, under no circumstance charge multiple batteries in parallel unless the charging system was intentionally designed for that duty. Chargers of that type are usually prohibitively expensive for teams to own.
Unread 12-02-2004, 09:22
from an engineering perspective, you can buy 6 amp battery chargers off the shelf that have been extensively tested, that have built in safety features, and are UL approved - and they will charge the batteries as fast as is possible without damaging them
if you build your own custom charger, you cannot charge the batteries any faster, you will take away limited time from other (robot) work you could be doing instead and you will have a much greater risk of system failure - either not charging the batteries or cooking them to some degree
So as an engineer I would say, why custom design a functional system that you can buy commercially off the shelf as a commidity item, when all you have to gain is risk?
I would recommend spending your valuable time on some other design project that will make your team more competitive, or helpfull to other teams at the event - something that you cant buy at Wallmart because you havent invented it yet :c)
Unread 12-02-2004, 09:25
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Can I ask a question related to battery charing? Why is it that most battery chargers I see usually require a power supply to make it work.
Unread 12-02-2004, 10:00
Are you asking about charging circuits you have seen? Most commercial chargers are stand alone boxes.
Unread 14-02-2004, 21:19
Carpe diem
It was a joke, hence the wink.
The real reason for making it is to reduce clutter and organize the pit. I guess I could make a box to house the 6 amp FIRST supplied chargers. I thouht more than a handful of teams had battery charging boxes, but I guess not.
Unread 14-02-2004, 21:39
Mike,
Sorry to sound so strong in the reply but safety is a big issue for us. If I missed the smiley (and I rarely look at the graphics) I thought some other teams might think it was OK to do. You can't believe what I have seen other teams do as far as electrical goes. FIRST also has intervened and that is why the strict new rules and electrical parts this year, in my opinion.
Unread 16-02-2004, 10:00
Carpe diem
Mike,
Yeah, I agree with this being my 5th year in FIRST I have helped fix my share of troublesome wiring. I think the new rules will help simplify inspecting the robots. Only disadvantage i can see is running a thicker wire up an arm or similar. Oh well, still for the better, kudos to FIRST.
Unread 16-02-2004, 16:54
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
At one time, our team had a cable called a high-octane cable. This cable, in theory, allowed us to charge one battery from multiple chargers. Needless to say, its use has been discontinued.
We are still using the battery charger we got in the 2001 season - our 6A charger emitted a cloud of bad smell last year (but oddly no smoke) and was disposed of. I owned one of those 6A chargers myself, but it too broke, in a similar manner. Both of these chargers I had seen had broken while charging very old FIRST batteries, made by Yuasa, probably from the 2000 season.
I have a question for the electrical wizards out there. How would a charging system be properly designed to charge multiple batteries at one? I would think a nicely setup diode layout would prevent one battery trying to charge another, even if there was a chance for something like that. I spent plenty of time last year trying to design one, but I couldn't get enough diodes for the purpose. The problem becomes interesting, because each battery in the mesh will have discharged differently, and some batteries are older/stranger than others, and have different internal resistances.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
box grabbing matt111 3D Animation and Competition 3 27-01-2003 23:08
Quick release battery connector and 120 amps n[ate]vw Electrical 6 18-01-2003 23:41
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
Gray box limitations Tim Skloss Technical Discussion 1 23-01-2002 07:38
