Go to Post If you're the smartest person in the room, you're in the wrong room! - Ian Curtis [more]
Unread 11-02-2004, 22:04
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Team 930 2004… thing
Unread 11-02-2004, 22:05
shawny963 shawny963 is offline
shawny963 is on a distinguished road
Send a message via AIM to shawny963
Re: pic: Team 930 2004… thing
heres a strange perspective to a mechanism on our bot, shouldnt be too hard to figure out i think.
Unread 11-02-2004, 22:07
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
its an extendable, nonpivoting mast.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 11-02-2004, 22:09
occra 23.
AKA: ryo
None #1481
yeah, not hard to figure, but wow!
but is that rope?
its spectra
Unread 11-02-2004, 22:10
Solace's Avatar
AKA: Jake
spectra is awesome. I love that stuff.
...What is a man,
Jake
Team Paragon #571
Unread 11-02-2004, 22:11
it definitely can hold its weight, and then some
Unread 11-02-2004, 22:48
Umm Errr...
Can somebody please explain to me how these types of lifts work. How do you get somethign to go up by pulling down? I understand how the multistage cascading lifts work. Is is the same thing?
1139 Alumni
Unread 11-02-2004, 23:05
It is really quite simple, it works the same way as a series of pulleys except for the fact that we use hdpe bushings with slots for the spectra to run through instead of a pulley. So as we pull down on the line in the innermost tube it pulls the end of the middle tube up until it comes to a hardstop. Then the spectra runs to the top of the middle tube, through a bushing which sends it back down to the bottom of the outermost tube, which allows the outermost tube to be lifted also. This can all be achieved with one piece of spectra, and they can be pulled down also with the same line.
Unread 11-02-2004, 23:06
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
[shrinks]
what is spectra?
[/runs away]
Unread 11-02-2004, 23:08
spectra is the type of rope we are using. Its often used in sailing. I believe 1/8" spectra has a breaking strength of 1200 lbs., at least the stuff we have does.
Unread 11-02-2004, 23:38
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Spectra cable is great stuff. In 2000 we used it to left our robot off the ground. At first we tried using just steal cable and it snapped all the time. We found out about spectra and it worked like a charm, we were hanging our 130lb robot from a hook that was connected to this cable. We also had a foreign exchange student from France that year and she was also a sail boat racer. She was GREAT with this stuff and could tie some amazing nots that really helped us. As long as you keep an eye on fringing or snags this stuff should hold up great.
Purdue Alumni
Cummins, Inc.
Unread 11-02-2004, 23:40
Elgin Clock's Avatar
FRC #0237 (Black Magic)
A.K.A. to the camping world as "parachute cord"??
Or am I thinking of something else?
Unread 12-02-2004, 02:53
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Parachute cord is usually spectra wrapped in a nylon sheath to protect against abrasion.
Zan Hecht
"Life is an odd numbered problem — the answer isn't in the back of the book." — Anonymous WPI Student
Unread 12-02-2004, 18:44
Ah, gotcha... I used that a lot in Boy Scouts since it was easier to deal with than braided rope for most things. - And it didn't shed it's material like rope does! lol
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
