Go to Post FIRST is an addiction but at least it is one of the healthiest addictions you can have (if you wear your safety goggles!). - Pavan Dave [more]
Unread 12-02-2004, 09:18
Bob Steele's Avatar
AKA: Bob Steele
Need suggestions re: mounting FP gearbox
I was wondering if anyone might be able to give us some suggestions on how to mount the FP Gearbox. It doesn't really have any mounting holes or anything and we would like to use it to move our ARM (with attached sprockets and chain...) Anyone willing to post a pic of an old mount using this gearbox/motor? Thanks a bunch in advance for your time at this juncture.
Unread 12-02-2004, 10:05
Larry S. Larry S. is offline
#0281 (UpStaRT)
Larry S. is an unknown quantity at this point
Re: Need suggestions re: mounting FP gearbox
The SIMPLEST and quickest method I've used in the past is to just run a 3/4" (or is it 1/2") aluminum shaft through the center of the gearbox. (The holes in the plastic need to enlarged a bit. Then simply couple your sprocket to the white slotted output projection on the gearbox. I've made special adapters for it, but also used the black plastic adapter that comes in the kit too. You can probably just screw your sprocket to the adapter as long as you leave some space for the chain. (Big washers are handy).
The secret is to just let the FP motor sit on the shaft. The shaft is stationary. You need to keep the FP motor from rotating, but nylon ties work great for this. Just strap the motor to any frame part thats handy. Since the shaft isn't rotating, you have to make sure the sprocket rotates freely on the shaft too.
That's the easy way. Not elegant, but functional. Sorry I don't have pictures with me. I hope this helps.
A more elegant method is to make a 10 sided adapter that fits the white output projection and use bushings or bearings to ride on the shaft. But it's a lot more machining.
Larry S. team #281
Warning about the FP motors. I have never been able to get even 1/2 the rated torque from these motors. I've used them 4 times.
Unread 12-02-2004, 10:26
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Closest shaft size is 7/16". We sit the Fisher gearbox on a 1/4" thick aluminum angle and transfer punch the shaft position. Lower the hole a little 'just in case' and drill 15/32" or your bearing size. Support the shaft on both ends and constrain it along its axis.
The fisher gearbox will just sit on the shaft and the shaft will take the forces applied to your sprocket.
Andy Brockway
Team 716, The Who'sCTEKS
White Paper Discuss: 2 speed, Shift-on-the-fly TechnoKat Gearbox CD47-Bot Extra Discussion 35 23-01-2004 20:16
Shift on the fly LEGO gearbox rlowerr_1 Robot Showcase 17 14-07-2003 23:33
Drill gearbox clutch Joe P Technical Discussion 3 12-03-2003 13:22
drill motor mounting whynot Technical Discussion 3 03-02-2003 08:24
new bosch pinion and mounting ajlapp Motors 1 08-01-2003 17:16
