Go to Post I can't wait until IFI starts their FRC sized competition and quickly overtakes FRC. - AdamHeard [more]
Unread 11-02-2004, 19:49
Matthew_H's Avatar
Matthew_H Matthew_H is offline
Ubergeek
#1028 (Ubergeeks)
Matthew_H will become famous soon enough
Send a message via AIM to Matthew_H Send a message via MSN to Matthew_H
Adding objects
How do we insert objects in the middle of the timeframe of our animation? We are trying to make light projectiles come out of an object.
Matthew
Unread 11-02-2004, 19:52
quickie25's Avatar
quickie25 quickie25 is offline
quickie25 is an unknown quantity at this point
Re: Adding objects
turn off animate, insert your object, turn animate back on.
You might consider inserting the object at the beginning of the timeframe and scaling to '0' until you actually need it to appear, then change the scale and you are set.
Hope this helps....
Team 1380
alloy - a mixture containing two or more elements fused together...(ie. A Team)
Unread 11-02-2004, 23:20
Matt Hallock Matt Hallock is offline
#1188 (Oaktown Crewz)
Matt Hallock is on a distinguished road
Send a message via ICQ to Matt Hallock Send a message via AIM to Matt Hallock Send a message via Yahoo to Matt Hallock
Re: Adding objects
Could you go a bit more in depth on 'appear'? Are you looking for it to fade in, pop up, slide in, etc.
Lead Animator for Donder-Kimball High School, team #1188.
Unread 12-02-2004, 09:28
Matthew_H's Avatar
Ubergeek
#1028 (Ubergeeks)
Re: Adding objects
If you were to look at our animation you would all the sudden see the object that we are looking at.
Matthew
Unread 12-02-2004, 16:12
rrockafellow rrockafellow is offline
rrockafellow is an unknown quantity at this point
Re: Adding objects
Animate the visibility track of the object.
Unread 12-02-2004, 19:33
Re: Adding objects
Move your object to where you want it and then change your tangeants to step and it will appear at that frame.
Envioments for showing off objects MConte05 3D Animation and Competition 4 18-01-2004 01:00
Adding realism through plugins or alternate rendering engines anishthakkar 3D Animation and Competition 3 10-01-2004 17:26
Mobile/immobile objects on field Steve782 Rumor Mill 12 08-01-2004 04:15
Map Coordinates on imported objects Jacob Reif 3D Animation and Competition 2 04-02-2003 01:27
Help - objects won't move in Max Kevin Thorp 3D Animation and Competition 7 28-01-2003 12:49
