Go to Post The best way to get to Einstein is to analyze the game, figure out which three robots would make up the ideal Einstein alliance, and then design, build, iterate, and polish the one that best matches your teams' capabilities. - Jared Russell [more]
Unread 11-02-2004, 21:41
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: IR captured in photo (4 IR LEDs @.1A DC ea)
Unread 11-02-2004, 21:42
Umm Errr...
Re: pic: IR captured in photo (4 IR LEDs @.1A DC ea)
Originally Posted by CD47-Bot
Thread created automatically to discuss this image in the Picture Gallery.
Yup make yourself an array of them and you have a flashlight that only your camera can see. = really bootleg night vision
1139 Alumni
Unread 12-02-2004, 14:02
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Ehat camera did you use for this picture? My camera can hardly see anything when pointed at the beacon.
Unread 12-02-2004, 16:14
any old camcorder will see IR remotes and LEDs
try turning the lights off, or hold the LED closer to the camera - BTW this is a good way to check and see if they are working
Unread 12-02-2004, 22:22
Somebody else posted that newer cameras have better filters and block more of the IR
Unread 13-02-2004, 16:38
Dale(294engr]'s Avatar
Dale(294engr] Dale(294engr] is offline
Mentor/Sponsor since '98
Dale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of lightDale(294engr] is a glorious beacon of light
Camera used: Olympus 3040, digital, 3 megapixel, flash off, macro focus on
This photo was taken with an IR LED powered from a
5 VDC voltage source drawing .11A (33 ohm kit current limit resistor)
i.e. 100% ON duty cycle....
to make it easy for the digital camera to see.
See my other IR Beacon photos in the gallery
showing the much dimmer (but visible) LED illumination when pulsed/burst
<1 mS burst of 40 KHz pulses, & low duty 100Hz rep>
emitter 0:
pulsed at 40 kHz (50-50 duty square wave)
burst for 40 cycles = 1mS (total ON time = 500uS)
and 100 Hz repetition rate (total Off time = 9500uS)
500*100/(9500+500) = 5% ON duty time
use emitter 1 (to improve cameras ability to see IR a bit)
80 cycles = 2mS (total ON time = (.5*2mS) =1000uS)
and 100 Hz repetition rate (total Off time = 9000uS)
1000*100/(9000+10000) = 10% ON duty time
pic: Technokat and WBI Group Photo. CD47-Bot Extra Discussion 8 13-05-2003 09:35
