Go to Post I, for one, have no particular problem with singing, dancing and sex appeal. Mark Leon combines all that with a career at NASA! - Rick TYler [more]
Unread 12-02-2004, 14:59
kingpin3787 kingpin3787 is offline
kingpin3787 has a little shameless behaviour in the past
Transmission Problems
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THIS IS TEAM 1340
WE THINK OUR TRANSMISSION FOR THE DRILL MOTORS ARE BAD.
WHEN WE GO IN REVERSE ONE OF THE MOTORS STICK & GRIND & ITS SOUNDS HORRIBLE COMPARED TO THE MOTOR THAT WORKS FINE.
ANY ADVICE OR WEBSITE THAT YOU THINK CAN HELP HOLLA BACK @ US. !!!!!!!!
Unread 12-02-2004, 15:08
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
Re: Transmission Problems
THIS IS TEAM 1340
Are you actively shifting the gears, or are you using a single fixed gear?
Generally, the above problem is due to the transmission popping out of gear.
If you're shifting, check your shifter to be sure it can generate (and hold) enough force to keep the transmission in gear.
If you're not shifting, you'll need to add something to the drill motor to keep the shifter in place, or else it will pop out of gear. You can make a spacer-collar to put around the outside of the motor, you can make a spacer ring to put in the transmission itself, or you can maybe think of a creative way to tie-wrap it in place.
-Chris
Unread 12-02-2004, 15:47
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Make sure that the torque setting (the numbered thingy at the end) is on drill and not some number. The drill setting looks like a little drill bit.
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 12-02-2004, 22:38
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Also, make shure that the drill tranny is not coming apart. The tranny uses a twist-lock system to hold the 2 halves together. I saw many teams last year that broke the tabs in this twist-lock system because the drill tranny mounts in the kit don't give the best support.
Matt
Unread 13-02-2004, 02:43
aznbomber's Avatar
aznbomber aznbomber is offline
aznbomber is an unknown quantity at this point
-Chris
How can we change the transmission in order to keep the shifter in place? I believe our robot is exactly that. When we place the robot on the floor, the wheels won't spin unless we start it off slowly and even then it will still make clicking sounds.
Thanks
Howard
Unread 13-02-2004, 07:25
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Originally Posted by aznbomber
... When we place the robot on the floor, the wheels won't spin unless we start it off slowly and even then it will still make clicking sounds.
Thanks
Howard
That sounds very much like the torque setting referred to above. If the problem was the shifter popping out of gear then I don't think your bot would move at all.
The large black cover over the front of the transmission has numbers on it which represent the level of torque you will get before "slipping". I would guess that is the clicking sound you are hearing. If you turn that cover past its highest setting you will get to an small graphic that looks like a drill bit. That is where you want it set.
Hope this helps ... I wish I could take a picture and post it - a picture is worth at least 1000 words in this case ...
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 13-02-2004, 09:01
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
You can use zip ties to keep the shifter in place. Make sure you get the shifter push all the way in the direction you want and secure a zip tie on the back of the shifter. Tight but not overtightened. That how are team solves this problem. As for if the transmission is coming apart, get better motor mounts. We got new motor mounts, non-kit, post season after having trouble later with the motor and transmission becoming un-meshed. Disadvantage is that it would cost you weight. We didn't have real motor mount problems til post-season.
Unread 13-02-2004, 09:19
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
There is a very close thread to this one with a good summary answer of where to find help.
http://www.chiefdelphi.com/forums/sh...threadid=25202
I am closing this thread to help consolidate things a bit.
Joe J.
Technokats transmission Porterhouse04 General Forum 3 16-01-2004 19:06
Do you all have problems with.... Munkaboo Website Design/Showcase 19 03-03-2003 19:51
Help!!! Transmission problems Scooter General Forum 4 19-02-2003 15:33
Joystick problems archiver 2001 3 24-06-2002 02:40
Radio problems -- not archiver 2000 1 23-06-2002 22:23
