Go to Post You know you're addicted to FIRST when...You relabled the speedometer in your parents car so that 0 is 127 - Sharkbyte [more]
Unread 07-02-2004, 14:11
Can someone post this on FIRST q/a
Can someone post this for me, as the person with the password is unreachable for a while.
Section 5.2.6
<R20> May we use a different Quick Disconnect connector for the battery then the one provided in the kit? Specifically, we would like to use the Anderson Power Products SB120 (the next size up from the ones in the kit).
Unread 07-02-2004, 15:35
Electrical Engineer
Rookie Year: 1995
Re: Can someone post this on FIRST q/a
Done...
Mike Betts
As easy as 355/113...
Unread 07-02-2004, 16:40
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Good question, as it never made sense that a 50 amp connector would be used when our circuit breaker is 120 amps. I'll include the obligatory link to 190's melted connector.
However, the SB120 is very large and heavy (it's about twice the size of the current FIRST conector, the SB50). You might want to go for something in between, such as the SBO or the SBE80.
Zan Hecht
Unread 07-02-2004, 18:22
Zan, we also used the SB120 last year, and yes it is larger and heavier, but not terribly so.
Unread 08-02-2004, 07:42
Guys,
It wil be interesting how First responds to this question. The rules are not really clear in that they recommend the supplied connector as a minimum but indicate if you use something else you may not be compatible with other team's connectors. We use a Tyco/Amp connector that is available from Newark. It is designed for 100 amps, works well with #6 wire and looks like a larger version of the Anderson power pole connectors. We have used these for several years now. Remember to add mating connectors to your battery charger.
Unread 08-02-2004, 16:34
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Originally Posted by Al Skierkiewicz
Guys,
We use the supplied connector every year and it's proven to be helpful during finals. When it gets down to that finals crunch, you want to have good charged batteries, and often times you run clean out. Luckily, sometimes you'll have an alliance that brings 20 batteries and has some amazing charging system devised. You borrow a battery from them for the match. Thats our thinking at least.
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 08-02-2004, 17:06
DanL DanL is offline
Crusty Mentor
FRC #0097
DanL is just really niceDanL is just really niceDanL is just really niceDanL is just really niceDanL is just really nice
Send a message via AIM to DanL
This topic has been brought up in a quite a few threads. In one of them, it was said that you can make a simple adapter with the kit connector on one end and your connector on the other.
Dan L
Team 97 Mentor
Software Engineer, Vecna Technologies
Unread 08-02-2004, 19:51
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
When we read the rules, we never got the idea that other connectors of different ratings were permitted. So, we were thinking of using two in parallel, mounting them in such a way that they would act as one unit.
If this would be allowed, it would be a great help.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 09-02-2004, 07:27
That is actually a great way to double up the capability. The downside is the added weight. Make sure everything is tight and well insulated. I would like to see it if we are at a comp together. Come and find me if you can.
Unread 09-02-2004, 11:49
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
That would ensure compatibility with other team's batteries too. Good Idea!
Unread 12-02-2004, 12:57
Well, FIRST answered no on the different battery connectors issue. The full response:
Section: 5.2.6 Status: Answered Date Answered: 2/12/2004
Q: <R20> May we use a different Quick Disconnect connector for the battery than the one provided in the kit? Specifically, we would like to use the Anderson Power Products SB120 (the next size up from the ones in the kit).
A: No. Use tie wrap to hold provided connector together.
Do you think they misunderstood the question, or do you think the ruling is no different battery connectors?
Venkatesh, you should probably ask about your method.
Unread 12-02-2004, 13:19
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
Honestly, I am very wary about borrowing batteries from other teams after last year. We borrowed a battery from a local team for national and we ended up not moving one match because of a dead cell. That hurt us tremendously since it was in qualification. We ended up seeding like fourth or fifth but without a bad cell we could have easily been 1st. And you remember the number 1 alliance from Archimedes (wildstang, las guerillas, husky brigade). So I wouldn't completely trust a borrowed battery make sure you test it before, because when you're not moving, a minute and 45 second is a long time.
Unread 12-02-2004, 14:25
This is a vast difference in policy from previous years. The rules specify "a" quick connect not "the" quick connect. Standby for further info.
We currently have 8-10 batteries, several chargers, four past year's robots and a prototype and robot from this year all wired for a different connector.
Unread 12-02-2004, 15:41
Aidan F. Browne's Avatar Unsung FIRST Hero
Aidan F. Browne Aidan F. Browne is offline
Engineer
AKA: The Aidan-bot
Aidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond reputeAidan F. Browne has a reputation beyond repute
New connector rule
Al --
Please read the whole rule. The intent is that the connector provided in the kit is the connector that must be used. This is not an error.
"<R20> The 12v battery must be wired directly to a quick connect / disconnect connector (provided in the kit)"
As you can see, the rule clearly states that the connector is provided in the kit. The reason that the word "a" was used, is that there are two of the connectors provided (the entire connector is made up of two mirror-image halves).
Sorry to hear that all your previous equipment uses a different connector - but for 2004 the rule has changed.
Aidan
Unread 12-02-2004, 16:01
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: New connector rule
Do you happen to have any insight as to why the rule was changed? Using a different connector (assuming it's rated for at least the same amount of current as the provided one) does not cause any safety issues or add any unfair advantage that I can think of. This seems to fly in the face of the notion that the rules were going to be kept simple this year and that common sense should prevail. To me, this is like asking "Can we use #8 wire in place of #10?" and being told "no".
Rules like this would be a lot easier to accept if there was at least an attempt made at providing a reason.
Additionally, I read the passage from the manual that you quoted as "You need to use a quick disconnect, and there happens to be one provided in the kit." I don't read it as implying that it's required to use the one in the kit, but apparently that's what it meant.
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 30-03-2003 23:00
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 12-01-2003 22:19
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 05-01-2003 22:04
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 05-05-2002 22:07
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 04-02-2002 00:39
