Go to Post And that's why we all need to consider reserving a "No! Bad robot!" button for the robocoach. :yikes: - vhcook [more]
Unread 12-02-2004, 16:01
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: New connector rule
Originally Posted by Aidan F. Browne
Sorry to hear that all your previous equipment uses a different connector - but for 2004 the rule has changed.
Do you happen to have any insight as to why the rule was changed? Using a different connector (assuming it's rated for at least the same amount of current as the provided one) does not cause any safety issues or add any unfair advantage that I can think of. This seems to fly in the face of the notion that the rules were going to be kept simple this year and that common sense should prevail. To me, this is like asking "Can we use #8 wire in place of #10?" and being told "no".
Rules like this would be a lot easier to accept if there was at least an attempt made at providing a reason.
Additionally, I read the passage from the manual that you quoted as "You need to use a quick disconnect, and there happens to be one provided in the kit." I don't read it as implying that it's required to use the one in the kit, but apparently that's what it meant.
Unread 12-02-2004, 17:50
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
Re: Can someone post this on FIRST q/a
Could someone post a question related to my method on FIRST's Q&A? I won't have the ability to post that question for some time.
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 30-03-2003 23:00
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 12-01-2003 22:19
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 05-01-2003 22:04
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 05-05-2002 22:07
ChiefDelphi Forums Community Bulletin Brandon Martus CD Forum Support 0 04-02-2002 00:39
