Go to Post This isn't an engineering fair and demonstration, it's FRC. Defense is part of the game. You can't expect a good FRC team to just sit there and get clobbered by a full-court shooter; they're going to engineer a solution to the problem. - Kevin Sevcik [more]
Unread 12-02-2004, 18:04
zainali's Avatar
zainali zainali is offline
AKA: Syed Zain Ali
#1241 (Theory 6)
zainali is an unknown quantity at this point
Question Current sensors wiring
When wiring the current sensors do you have to connect the two pins at the top to the circles on the side and then connect it to the speed controller and the drill motor.
Rick Hansen Secondary School
Team 1241
www.Theory6.org
GO LEAFS GO
Unread 12-02-2004, 18:07
Rhs953's Avatar
Rhs953 Rhs953 is offline
Revenge is near...
AKA: Mike
#0953 (Illumanati)
Rhs953 has a little shameless behaviour in the past
Send a message via AIM to Rhs953
Re: Current sensors wiring
That would work. You should have no problem.
Heh im typing with my arms over a drill motor as im giving it a haircut.
___________________________
If all else fails, use a bigger hammer.
Unread 12-02-2004, 18:08
zainali's Avatar
AKA: Syed Zain Ali
#1241 (Theory 6)
Do you solder them to the circles using a wire or any other suggestions
Team 1241
www.Theory6.org
GO LEAFS GO
Unread 12-02-2004, 18:10
Rhs953's Avatar
Revenge is near...
AKA: Mike
#0953 (Illumanati)
use soddering wire..if thats what i think u mean..
let the sodder iron heat up. then out the wire onto what u want to sodder. then lightly touch the wire with the iron.
Unread 12-02-2004, 18:11
zainali's Avatar
AKA: Syed Zain Ali
#1241 (Theory 6)
thanks anyway figured it out
Team 1241
www.Theory6.org
GO LEAFS GO
Unread 13-02-2004, 00:39
Random Dude Random Dude is offline
Oregon State Head FTA
AKA: Chris
no team (Oregon Robotics Tournament & Outreach Program)
Random Dude will become famous soon enoughRandom Dude will become famous soon enough
Just to clarify, (I assume you already realized this, but better to be safe), you don't need to run any wire from the leads of the IC to the bolt holes. Just solder the IC in place. The board already has traces on it to conduct the power.
Current Sensor Joshua May Programming 6 12-02-2004 10:48
Harmful side effects with current sensors m0rph3us Electrical 2 11-02-2004 07:31
current draw sensors zainali Technical Discussion 2 08-02-2004 11:40
wiring diagram for light sensors??? pagemauck Control System 1 21-01-2004 16:32
