Go to Post I always mean what I say. I just don't always say what I mean. - dlavery [more]
Unread 01-02-2004, 15:22
Teedoff101 Teedoff101 is offline
#0992 (Oakwood Robotics)
Teedoff101 is an unknown quantity at this point
Ground Stud
In the FIRST Power Distribution Diagram, there is a part labeled "Ground Stud" in box C8. We have no log of this in our inventory, and are in need of using it. Does any team have a picture of this or can explain to us what it looks like? Thank you very much for your time.
Team 992
Unread 01-02-2004, 15:45
Re: Ground Stud
This is what the ground stud looks like: courtesy of firstcadlibrary.com
Unread 01-02-2004, 15:56
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Ground Stud
Team 992
It was supposed to be in the Terminal Supply Bag, in the Blue Box. They came from www.terminialsupplyco.com, They have a not for online ordering web site. The bolt size is 3/8 " Good luck, BTW finding a supplier with a picture is hard, glad some one was smart and looked in the first drawings.
Unread 01-02-2004, 16:22
Bruce C.'s Avatar
Bruce C. Bruce C. is offline
#0647 (The Cyber Wolf Corps)
Bruce C. will become famous soon enough
Re: Ground Stud
Our team still hasn't received the terminal bag, or the IR sensors and beacon LEDs (Grrr). We're using a 1/4 x 20 bolt through a piece of lexan as a ground stud. I hope FIRST is a little understanding of the problems they have caused by not having critical parts shortages shipped to teams in 3 WEEKS.
Unread 12-02-2004, 22:09
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
Re: Ground Stud
we still haven't recieved our missing parts (terminal supply bag) we need a ground stud (insulator stud) is there a way that we can make a temperary one?
thanx
Unread 12-02-2004, 22:16
NoRemorse's Avatar
NoRemorse NoRemorse is offline
FOCUS Integration, LLC - Owner
AKA: Brian Roberts
FRC #1023 (Bedford Express)
NoRemorse has a spectacular aura aboutNoRemorse has a spectacular aura about
Send a message via AIM to NoRemorse Send a message via MSN to NoRemorse
Re: Ground Stud
this as JUST posted and seems to aswer your question quite nicly i think
http://LSJBuildUp.com -Documenting the build of my LSJ, as well as other influential cars.
Unread 12-02-2004, 22:22
Vince lau's Avatar
FRC #4914
Re: Ground Stud
is it safe? we don't want fry anything
Unread 12-02-2004, 22:23
NoRemorse's Avatar
AKA: Brian Roberts
Re: Ground Stud
as long as the bolt *safly* dosnt touch any metal other than ground wires, you should be fine
Unread 15-02-2004, 15:25
jacob_dilles's Avatar
jacob_dilles jacob_dilles is offline
AKA: theshadow
FRC #0620 (WarBots)
jacob_dilles will become famous soon enough
Send a message via AIM to jacob_dilles
Re: Ground Stud
yeah our team did not recievec any ground stud, i took a piece of angle al and drilled a bunch of holes in it. the botom is electricly insulated from the chaises with a piece of lexan that was epoxyed to it (over the bolts). as long as you dont touch the frame, almost any handy piece of metal works great.
last year i had a fun experence with a home made ground bus, the bolts shorted to the frame and when the positive lead of the battry went floping around... big blue spark! dont do it
"You're not a real programmer until all your sentences end with semicolons;"
Unread 15-02-2004, 22:57
Re: Ground Stud
The ground stud is a required part of the electrical system. It may not be eliminated or substituted. The electrical system drawing must be followed unless you do not use the maxi block and 40 amp circuit breakers.
Unread 15-02-2004, 23:31
Guest
Posts: n/a
Re: Ground Stud
Might you ship with your subsititute and then put the real stud in at your first regional? This way, your robot can be approved by FIRST during practice day and you have a fully functional 'bot.
Hope you get your parts soon!
Unread 16-02-2004, 07:20
Re: Ground Stud
Any thing is OK as long as it is correct by the time your are inspected. Don't forget that the stud is 3/8" so the terminals must be large enough to fit it when you change.
Is it illegal to lift another robot off the ground? Tton Rules/Strategy 19 14-01-2003 21:28
FIRST looses even more ground in the war for TV fame?? archiver 2000 4 23-06-2002 23:53
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
Can we ground our wires to the frame? mnkysp6353 Electrical 1 15-02-2002 20:47
Our wheels don't touch the ground! ahecht General Forum 12 29-01-2002 19:35
