Go to Post p.s. note that 5-1/2 hours in the car with your daughter on the way to IRI is NOT the same as 10 hours in the van with seven members of Team 116 on the way to IRI. One is a wonderful familial experience, the other is an opportunity to go insane. - dlavery [more]
Unread 12-02-2004, 19:20
magical hands magical hands is offline
Jigar Patel
AKA: Jigar Patel
FRC #2185 (Etobicoke CI)
magical hands is on a distinguished road
Question Navigational problem
Hi! I got this code from Mr. Kevin's site which is navigate.zip file and i dowload it in the robot and I connect the servo motors to pwm1 and pwm2 and IR sensors to analog I/O but the sensors and servo motor's don't work anyone has any idea why? We are following all the steps there are and our sensor and servo motor's are fine becasue we tried them on edu Rc and they work so they should work on frc as well but they don't?
Unread 12-02-2004, 22:24
Re: Navigational problem
Originally Posted by magical hands
...servo motor's don't work...
If your servos don't work, first make sure you have a good 7.2v battery connected.
Unread 13-02-2004, 07:15
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
... IR sensors to analog I/O ...
The IR detectors should be connected to digital inputs. You need to read the comments in receiver.c (or is it receiver.h?) to see which digital inputs to use.
-Joel
Unread 14-02-2004, 20:56
deltacoder1020's Avatar
deltacoder1020 deltacoder1020 is offline
Computer Guy
AKA: Dav
#1020 (The Indiana Prank Monkeys)
deltacoder1020 has a spectacular aura aboutdeltacoder1020 has a spectacular aura about
Send a message via AIM to deltacoder1020
this has been mentioned before, but if you are just wanting to test the servos, use tracker.zip, not navigate.zip - navigate is designed to drive the robot to the beacon, whereas tracker simply locks the servos onto the beacon.
Team 1020, the Indiana Prank Monkeys (www.team1020.org)
Victor problem Andy Baker Electrical 15 24-06-2003 09:49
Ok one problem cantwell03 Programming 3 13-02-2003 07:28
The problem with scouting... archiver 2001 10 23-06-2002 23:49
joystick problem archiver 2000 12 23-06-2002 23:08
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
