Go to Post Careful what words you use here; we take them literally. - DonRotolo [more]
Unread 13-02-2004, 14:04
Dinush Dinush is offline
Build Team!!
AKA: Dina Begun
#0912 (Iron Lyons)
Team Role: Student
Dinush is an unknown quantity at this point
Send a message via ICQ to Dinush Send a message via MSN to Dinush
Re: Line sensor wire gauge questions
I was also unsure because I soldered the blue wire in the line sensor to a PWM pin which connects to the Digitali I/O ground, but in the circuit diagram, it shows the line sensor connecting directly to the ground on the circuit breaker.
And in the rule book it says:
"Sensors may not be wired in series with their loads to directlyu control those loads"
Which is why I was wondering about running one wire from the 20amp circuit breaker and cutting off parts off the insulation and sodering the brown wire of each sensor to the +12V wire.
It also says:
"The loads must be controlled by PWM signals sent by the Robot Controller to relays or speed controllers"
What exactly is this reffering to? Does this mean that the power of the sensors has to be controlled by the microcontroller through a relay?
--> 2003: Winners of Canadian Regional. Thanks 1088 and 378!
Sprockets and Roller Chain Models Madison Inventor 3 04-02-2003 11:51
Q&A Discuss: Does the line continue up the ramp? CD47-Bot Extra Discussion 5 18-01-2003 01:01
iParts on firstcadlibrary.com Ed Sparks Inventor 3 08-01-2003 23:30
approach to autonomy Mike375 Programming 32 08-01-2003 14:04
emulationFIRST v0.04 Matt Leese Programming 7 09-07-2002 08:54
